Wiring Batteries
Wiring Batteries
Home › Forums › R/C & Accessories › Wiring Batteries
  • #11615
    Kevin Bellman
      @kevinbellman86047
      Hi Guys,
      Got a mental block and need some help.
      I have 2 x 6 volt Ni-Mh batteries which I wish to connect to a single motor via ESC, i.e. 12 volt through the motor. At the same time I need to be able to tap of 6 volts for accessories. Can some one please suggest how to wire this up.
      Cheers Kevin
      #11618
      Manxman
        @manxman
        Hi Kevin,
        Its simple enough and I’ve done a diagram for you, but because this editor is not very friendly, I can’t attach it to this reply !  I’ve asked for help on this before but no one has come forward with how to do it.
        So I will try to describe how to in text !
        Have the 2 x 6v batteries in front of you and wire the POS+ of one battery to the NEG- of the other and thats it.  The remaining two outside terminals +- will now give 12v to your motor.  For the 6v simply take a lead from both terminals of one battery only +- will give you the 6v tap you require.
        What you’ve done here is to wire the batteries in series – doubling the voltage but not the amperage – ie.  2 x 6v7a = 1 x 12v7a
        Hope this helps without the diagram
        Cheers – Kenny
        #11620
        Kevin Bellman
          @kevinbellman86047
          Thanks Kenny,
          Obvoius now…wood for trees!
          Regards Kevin
          #11631
          Len Ochiltree
            @lenochiltree67043
            Hi Kenny,
            What I did to put a sketch on,was to photo it then put it in my gallery,
            Len.
            #11637
            Manxman
              @manxman
              Yes, I’ve done that before with a wiring diagram Len.
              The problem there,  is it can take a number of days before it goes live,  Updated my image picture this morning and its still not been replaced,  I’m a just shadow of my former self !
              Ken
              #11638
              Vinnie Branigan
                @vinniebranigan92297
                No.  All images now go live straight away.  Avatars are different, they have to be approved, and may not be.
                Vinnie
                #11694
                Len Ochiltree
                  @lenochiltree67043
                  Avatars? Er??
                          Len
                  #11696
                  Manxman
                    @manxman
                    I was going to ask the same question Len.
                    I think over the weekend I’ll nip to Aldi’s – they had some cheap (just love that word!) graghic tablets for sale.
                    Cheers – Ken
                    #11703
                      Dear All
                      The term Avatars just shows that Vinnie has had a classical education and we should all be glad that he in in charge of what is posted.
                      An Avatar is a being who presumes that he is a god or has god like abilities but usually their only claim to omnipotence is the wearing a light blue track suit.
                      However in this case I assume that it means a computer generated personality or handle (name) of the Internet user as used in Internet forums. for example my picture of the fat controller is in fact an avatar (wherein a two dimensional character as used in computer lingo)
                      Well done Vinnie your replies continue to amuse and educate.
                      #12095
                      Gary Radford
                        @garyradford51412
                         Looks like you get the same problems on this site Vinnie
                         Cheers.
                          Gaz.
                        #12096
                          Vinnie doesn’t have problems he just has challenges
                          #12099
                          Gary Radford
                            @garyradford51412
                            #12103
                              Hi Gary
                              I still feel sorry for Vinnie as he has so much to do.
                              #4938
                              Kevin Bellman
                                @kevinbellman86047
