Welcome to Model Boats!
Home › Forums › Beginners › Welcome to Model Boats!
Viewing 25 posts - 1 through 25 (of 25 total)
  • #9874
    Vinnie Branigan
      @vinniebranigan92297
      Hi, and welcome to the new look site! With your help this site can grow and hopefully become one of your first stops on the internet, so why not come on in, join up and maybe win a superb Hold and fold from Cammetts!
      Vinnie
      #9875
      Charles Reading
        @charlesreading80470
        Hi Vinnie,
        Good luck on the new site….all looks to be good.
        Hope to learn something about ships and boats here as I am a complete novice in this field.
        Cheers,
        Charles
        #9876
        Vinnie Branigan
          Hi Charles! Any warmer yet in LA? It’s gorgeous here! Welcome to the site, and I hope to see lot’s more of you around here!
          Vinnie
          #9877
          Charles Reading
            Temperature actually dropped over the past several hours and it’s getting ready to rain.
            Trying to stay inside and build models.
            Cheers,
            C.
            #9878
            Jeremy Wee
              @jeremywee41809
              Here’s popping into this alien world of boats too!
              Looking good so far!
              #9912
              Seaspray
                @seaspray
                I am just having a wee look around.
                #9963
                Tony Littlejohn
                  @tonylittlejohn18848
                  Hi Vinnie the site is looking good keep up the good work.
                  #10067
                  brendon nesbitt
                    @brendonnesbitt60522
                    Do you know of any websites where I can buy R/C boat kits?
                    #10068
                    Seaspray
                      @seaspray
                      E-bay or Google search for model shops or the Model Boats in the magazine directory or try Westbourne Model Centre Bournemouth 01202763480 they have a web site. Lots to try
                      #10075
                      Quinn
                        @quinn
                        Hi. New to the forum and to RC Scale Boat Modeling. Glad to see this site is back up – heard about it through the RC-Controllers forum.
                        I’ll be monitoring.
                        #10077
                        Seaspray
                          @seaspray
                          Welcome aboard Quinn
                          Hopefully it will grow to what it use to be
                          #10083
                          brendon nesbitt
                            Can anyone help? Is there a recommended distance between the end of the hull to the props. A m i right in thinking that the closer to the hull the less it will plane and vice versa. Thanks for any help
                            #10085
                            Seaspray
                              @seaspray
                              Yes. Always refer to the plan if you have got one.Both the distance and angle from the hull is important.Also size of prop and engine too.The angle is obtained by fitting the correct engine mount and the distance by the correct size of shaft. some scratch built model just won’t accept exact prop/rudder positioning in a model.Experiment or ask somebody with the same model.The layout of radio/ fuel tank or batteries to trim the boat is paramount as is wieght of the above.
                              If your running an i.c. engine the water scoop behind the prop it to has to be correctly position in the wash of the prop to assist in pushing the cool water through the pipe work.
                              Various books available an old Vic Smeed one may suit
                              Lets know how you get on
                              #10127
                              Bill Furey
                                @billfurey25085
                                Hi Vinnie,
                                The site looks good….only new at this…hope to spend lots of time on here and gain valuable knowledge from the more experienced members.
                                Bill
                                #10128
                                Vinnie Branigan
                                  Hi Bill, welcome to the site!
                                  Vinnie
                                  #10129
                                  Bill Furey
                                    @billfurey25085
                                    Vinnie,
                                    Thanks mate.
                                    Starting to get very cool over here in Aust. I suppose you are starting into the warmer weather now? “Lucky blokes”.
                                    Bill
                                    #10130
                                    Vinnie Branigan
                                      Not to bad today, but way too warm yesterday!
                                      Vinnie
                                      #10131
                                      Bill Furey
                                        @billfurey25085
                                        I suppose I cannot complain, we are just coming out of a drought here in Victoria.
                                        #10225
                                        brendon nesbitt
                                          Hi Chaps.Firstly i have subscribed to the mag.Ive recieved my free gift (fantastic) now how do i access the subscriber only content? Secondly I am making HMS Snowberry as my first boat made by myself.What cheap radio set up do you suggest.MY plan is a two channel reciever 1 motor 1 servo and a speed control working of 6 volts. Thanks for any help
                                          #10226
                                          Vinnie Branigan
                                            Hi Brendon, If you look through the list of feature articles, you’ll see which ones are subsciber only….but at the moment there are very few! That is set to increase in the very near future though!
                                            Vinnie
                                            #10252
                                            Barry Addis
                                              @barryaddis83049
                                              Hi Vinnie,
                                              Great site have just registered. Looks like as a complete novice to Model Boat building it will be of value to myself.
                                              Barry
                                              #10596
                                              Ian_G Hughes
                                                @ian_ghughes13480
                                                Hi Vinnie
                                                Didn’t know this was a new site i used to visit the old one. This is much more streamlined and user friendly.
                                                Currently making the Hachette KMS Bismark but using my some of my own techniques. With 200 issues I don’t think I will see it complete Anyway it looks nice so far and can be fitted with R/C
                                                Keep up the good work.
                                                Cheers
                                                #10641
                                                Ian Prudhoe
                                                  @ianprudhoe51849
                                                  Hi Vinnie
                                                  Just subscribed to ‘Model Boat’ and looking forward to getting my first new copy, just had ‘ hand me downs’ up to now. I’m just a novice really, i built a scratch model of the Norfolk Broads style cruiser ‘Ravenna’ last year but i got the hull twisted so it never was a good cruiser. I’m now restoring a Vosper PL4 over the winter, 46" bow to stern and 9" beam. So if it turns out good, hopefully i can share some pictures with everyone.
                                                  Great website by the way
                                                  regards
                                                  #10651
                                                  Robert McHutchion
                                                    @robertmchutchion86666
                                                    hi folks, a novice as well here, am doing hachette bismarck, hmcs snowberry and rnli lifeboat….all rc versions. going to be a long winter here in devon. i am a new subscriber to the magazine and new to the rc world, so if anyone wants to share horror stories, feel free.
                                                    cheers vinnie the site looks good
                                                    robert
                                                    #1322
                                                    Vinnie Branigan
