Hello Mark
Your comment sums up in a nutshell the problem that I have had in trying to find off the shelf motors specifically designed for large model tugs.
The T24, which I hasten to add is a perfectly good and well respected motor but for my purposes lacks the technical detail to enable me to work out its power consumption and power output.
A basic description of 12 pole, Hi Torque and Lo Rev doesn't cover detailed information such as the Amp operating range, RPM, or Output in Watts, and yet this is the critical information that a designer needs especially when specifying a large 2m model tug
Your Peugeot heater motor is a prime example of what model tug builders have to resort to when looking for a big 12v motor and yet apart from knowing its voltage what else, without hours of testing, do you know about its performance?
The lack of information is further compounded when trying to find suitable speed controllers, these heavy duty bits of kit are very expensive and we gamble with them whenever we connect them to a big motor with an unknown current draw.
