Springer Tug
Springer Tug
Home › Forums › Beginners › Springer Tug
  • #11062
      What is a FISHTAIL rudder please?
      #11063
      Manxman
        @manxman
        Hi Bob,
        Fishtail rudder – not heard this name before,  I think they are talking about a ‘Becker rudder’.  Where the last third of the blade moves in a greater arc than the front part,  this gives a curved look to the rudder when turning and should enable the boat to turn in its own length.
        Have a look at my album ‘Pacific Light’, I have two of these fitted.
        Go to page 8 of the album – this shows the component parts of the rudder and then to page 3 – were you’ll see them fitted (photos 123/124/125).  They are not a direct swap for a standard rudder, as they need a bottom pivot and a secondary top pivot point.  The one’s fitted here measure 100mm in height and are from ‘Graupner’ and cost £12 each.
        Cheers – Kenny
        #11064
          Thanks Ken
          I understand how it works now………………..it`s very clever……….a bit like flaps on an aircraft
           The name fishtail came from the previous posting showing a logging type tugboat
          #11066
          Len Ochiltree
            @lenochiltree67043
            Hi Guys,
            I met a Canadian Tug Captain who was over here visiting a Model boat Regatta, when he spotted my Springer Tug he seached me out to chat, he also sails models and it was him that suggested that I try a Fishtail Rudder,he did a fag packet plan for me,as you may know I dont like spending cash so I make my rudders, for the Springer Tug "Gazunder" the rules say rudder to be no more than 2" square, so I got a piece of brass sheet 2" square and soldered the upright post 1/2"in from the prop side then marked a line 1/2" in from the opposite edge and bent it 45deg,get another piece of brass sheet 2"x1"and bend it at 45deg so that when you put the two together they look rather like a snakes forked tongue,solder these together,blimey I hope this makes sense.I dont have any thing holding the bottom of the rudder but thats up to you.
            ps, There are no moving parts to this rudder.
            #11067
              Thank you Len…………………….it`s something new to me!
              #11072
              Manxman
                @manxman
                Hi Len,
                Your explanation sounds interesting, how does it fair in practise on your Springer ?. Even when going straight there would be a force on the rudder (both sides of the tongue) does this not slow the boat down.
                As to the Springer 2"sq. (total 4 sq. inches) rudder rule – is your rudder allowed ?, using 2 plates bent into a forked tongue as you describe, you would end up with a surface area of 2"x2.5" (total 5 sq. inches)
                Sorry to be a nit picker Len – but never the less it is an interesting rudder and one I’ll keep in my ideas file.
                Cheers – Kenny
                #11116
                Len Ochiltree
                  @lenochiltree67043
                  Hi Guys,
                  Nitpicking is allowed,but not recomended, I also forgot to mention that on the top and bottom of the rudder is a plate 2" x 3/4",add that to your calcs,
                  The fork doesn’t slow it down at all.
                  I can see that I will have to take a photo,but it is too cold now and I have just got up after working all night!
                  #11117
                  Manxman
                    @manxman
                    Cheers Len
                    They say a picture talks a thousand words – totally confused now – waiting for piccy !
                    Ken
                    #11150
                    Len Ochiltree
                      @lenochiltree67043
                      1630hrs it was winging its way across the ether.
                      Len
                      #11271
                      Len Ochiltree
                        @lenochiltree67043
                        Fishtail photo is now on my Gallery,
                        Len
                        #11272
                          Thank you Len!
                          I`ve  just had a look at Manxman`s  rudder on his Pacific Light and got the gist of it
                          I`m making one similar right now…….hope it works!
                          #11287
                          Len Ochiltree
                            @lenochiltree67043
                            Sketch of F/T Rudder on its way to my Gallery.
                                             Len.
                            Ps how do I use the "insert a link"thingy ?
                            #11293
                              No idea……I`m a bit behind the door in that respect!
                              #1409
