SLA Batteries
SLA Batteries
Home Forums R/C & Accessories SLA Batteries
  • #84110
    Andy Stoneman
      @andystoneman15177
      Another silly question maybe, I'm running out of space on a new project and wonder if its safe to lay an SLA battery on its side
      Thanks
      Andy
      #5576
      Andy Stoneman
        @andystoneman15177
        #84112
          Yes, it is OK to lay an SLA battery on its side but you need to be aware that it is denser at the bottom than at the top so the weight is not evenly distributed and you will either have to mount it off centre or provide compensating ballast at the terminal end.
          If you have not already bought the battery then a NiMH pack is a better option as you will get twice the usable capacity and running time for approximately the same weight.
          Andy Stoneman
            @andystoneman15177
            Hi Colin, I
            Thanks for the tip, I hadn't thought of the weight distribution problem, Ill take your advise and buy a NIMH set of batteries, much easier to handle and they won't affect the stability like the SLA battery would
            Andy
            #84127
            Kev.W
              @kev-w
              The only 'upside' to using an SLA battery, is if you need ballast, as in a tug , as it saves having to raid the local church roof for the lead. devil
