If the low voltage cutoff stops the motor, at what sort of level should I set my low voltage alarm to avoid getting stranded? I know some of it is trial and error but a good starting point is what I’m after. Motor leopard 1050kv on 3s lipo. Ta folks
Robin
I set mine at 3.4v/cell. Others may differ but any less is, to my mind, stretching it a bit. You will notice a drop off in performance well before you reach even this level, so it's not that critical.
Robin
There will be a default setting for everything already programmed into the ESC. I suggest you start with that. The only definite would be to make sure you have forward and reverse with no braking. To explain all of the other variables would take a long time – even if I understood them all myself. Harry Smith seems to have played around with brushless ESC settings more than most – you might have a shufti at some of his postings.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
