Props
Props
Home › Forums › All things floating › Props
  • #13566
    Jase
      @jase
      Anyone know where i can source a pair of M2 threaded 4 blade 25mm brass props?
      #13573
      Telstar
        @telstar
        Hi Jase
        M2 seems a very small dia. shaft for a 25mm prop. usually that size prop is fitted to a M4 or sometimes M3 shaft,  You could look at http://www.deansmarine.co.uk/html/propellers.html     but I think they only fit larger shaft sizes
        cheers Tom
        #13584
        ashley needham 2
          @ashleyneedham2
          Jase,  SHG Model supplies list 2mm shafts and brass props..I have not trawled thro to see if there are any 4 blade jobs, but a brass 3 blader may look ok in the interim. OTHERWISE i might suggest calling  the prop-shop… http://www.prop-shop.co.uk. as they do a good range of non-standard sorts of things, and should be able to thread some correct size props in 2mm for you ??. Ashley
          #3210
          Jase
            @jase
            M2 brass prop
