precedent perkasa 49″ instructions / parts list
Home › Forums › Building Kits › precedent perkasa 49″ instructions / parts list
  • #6213
    rob smith 4
      @robsmith4
      #61294
      rob smith 4
        @robsmith4
        Hi. As well as my schnellboot i'm also in posession of a glass fibre hulled 49" perkasa. The kit is unstarted but no instructions are present.
        would anyone have a copy of the instructions / parts lists ?
        it's possible that some of the parts may not be present and i'll need to check off whats there though everything is in the sealed bags.
        Many thanks Rob
        #61297
        CookieOld
          @cookieold
          Hi Rob , I have a full set that i have copyed for a guy over on Mayhem , would you like me to do some copys for you.
          rob smith 4
            @robsmith4
            that would be fantastic dave. please let me know what i owe you.
            cheers rob
            #61299
            CookieOld
              @cookieold
              It will be weekend before they are done , what neck of the woods are you in.
              Davewink
              #61300
              rob smith 4
                @robsmith4
                down in not so sunny devon. if you message me the cost and give me paypal details i'll sort it.
                by the way i just had a look at your pictures. some very nice work there. where did you get the alloy prop mounts ? or did you make them ?
                cheers.
                #61301
                CookieOld
                  @cookieold
                  Thanks Rob , I machined them out of billet ali same with the motor mount . When i started the build i found that the hull had a really bad twist in it that took some getting correct . I really hope you do not have the same issue.
                  Dave wink
                  #61302
                  rob smith 4
                    @robsmith4
                    Yeah I'm aware of issues with the hulls. Lets hope its ok. The kit was cheap if all is good.
                    I messaged you my details dave.
                    dont suppose you made spares of those alloy bits ? wink
                    cheers
                    #61303
                    CookieOld
                      @cookieold
                      Ha Ha sorry mate no , The prop supports were a swine to machine , but maybe could make you a triple motor mount.
                      rob smith 4
                        @robsmith4
                        that would be ideal.
                        I'd like to get it all looked over when i have the plans. If its worth progressing I'll be back you you on the mount.
                        what set up did you use with motors, props, shafts etc ? do you have blog on here for your build ?
                        Rob
                        #61305
                        CookieOld
                          @cookieold
                          This is my first model boat so there is no blog , When it came to the motors & props ect i was not a menber of this forum and was ill advised by a local model shop . Once i became a forum member it soon became apparent the motors and bats i bought were no good. I have ended up using 2 550 fan cooled motors on the outside props and a brushless motor in the center ( This will be used just when i want some not scale speed fun) .The props are 3X 35mm and bats are Nimh,s for the 2 550 motors and Lipo for the brushless . The model is 95% finished now and i will put some up to date photos in my gallery for you to see . I have to say without the help in the early days of the fine body of men on this forum i would have been screwed
                          Davewink
                          #61306
                            There's a fine woman too!
                            CookieOld
                              @cookieold
                              Sorry Colin , you are right silly me one forgets.sad
                              Best Regards Dave
                              #61441
                                Hi Rob
                                What brushless motor and is the props 2 or 3 blade 35mm?
                                I run my 25 inch Sea Hornet(1900kv motor) on a 32mm 3 blade(3S battery).
                                The motor ran to warm so I am going 2 blade 30mm.
                                #61444
                                CookieOld
                                  @cookieold
                                  Hi Rob , I will try and sort copys for you this week.
                                  rob smith 4
                                    @robsmith4
                                    all sorted now thanks
                                    #66490
                                    captainslog
                                      @captainslog
                                      Hi Rob, I have a set of plans and the instruction manual you are welcome to. There are also some fotos Of my finished perkasa 48" in my albums folder If you want to take a look. As I changed the stern gun I have a scratch built one spare if you want it. All I want is a contribution towards postage. Anyway let me know. good luck with the build, as you will see from my fotos I added stacks of detail as the kit is very basic. cheers keith
                                      #66508
                                      captainslog
                                        @captainslog
                                        that will teach me, should have read the date on the first posting, bit late I think. Never mind they are still up for grabs if anyone can make use of them.
                                        #83943
                                        Craig Kane 1
                                          @craigkane1
                                          Hi, Just came across this thread today. I've picked up a 49" hull but there are no drawings with it.
                                          Would anyone have a copy of the superstructure templates available?
                                          #83951
                                            Hi Craig
                                            I have all the booklets and plans.
                                            Message we with your email address and I will send them via We Transfer as they are large PDF files.
                                            Harry Smith
                                            FREE !!!!
                                            #83952
                                            Craig Kane 1
                                              @craigkane1
                                              Posted by harry smith 1 on 26/09/2019 08:33:14:
                                              Hi Craig
                                              Harry Smith
                                              FREE !!!!
                                              Hi Harry, message sent.
                                              Thanks
                                              #83975
                                              Craig Kane 1
                                                @craigkane1
                                                Posted by Craig Kane 1 on 26/09/2019 08:48:33:
                                                Hi Craig
                                                Harry Smith
                                                FREE !!!!
                                                Thanks
                                                Got the download, Harry. Thanks for your help.
                                                #83976
                                                captainslog
                                                  @captainslog
                                                  Hi cookieold, Not sure if it helps but I have about 10 fotos in my album of 1 i finished a few years ago. I used the basic build as per plans but threw many parts out and tried to do a scale version.There are many more detail fotos i have if you would like to see them. not sure if you got the plans but i have some yer somewhere. hope the album fotos help.
                                                  keith
