Perkasa fittings
Perkasa fittings
Home › Forums › R/C & Accessories › Perkasa fittings
  • #13156
    Fred Gray
      @fredgray24906
       I am looking for a full set of 1/24 fittings for the Precedent K.D. Perkasa. Model Dockyard used to carry them and they were made by TMD but are no longer available. Maybe someone out there has a set that they would like to sell. If so, please email me and I will arrange to purchase. email [email protected]
      #13180
        Hi Fred
        Try e bay they recently had a couple of full sets of Perkasa bits and pieces.
        All the best
        Fred Gray
          @fredgray24906
          Hi Paul
          Thanks for your quick response, will try ebay
          Regards,
          Fred
          #13208
          mick
            @mick
              hiya fred
            there is a gentleman on ebay that makes perkasa guns lockers  and torpedo s in
            made form these are not kits  i have had fitting s from this man and all you have
            to tell him the scale and what you require  the gentle man goes by the handle of
            boatman wales  hope this is of some help  mick
            #13211
            Fred Gray
              @fredgray24906
              Mick
                     Thanks for the information. As I am completely computer illiterate, how do I get in touch with boatman wales? Really appreciate your efforts.
              Regards,  Fred
              #13222
              mick
                @mick
                hiya fred
                try [email protected] if you need anymore info just let me know hope this helps mick
                also look on ebay for 40mm single barrel bofors gun on mk9 mounting for picture of his
                model fittings
                #13224
                Fred Gray
                  @fredgray24906
                  Mick,
                        Again thanks for the information, I will try these sites. I still need fittings for 20mm gun, vents, cooling tower, davits at torpedoes, misc. deck boxes, siting? devices at torpedoes etc. Any more ideas? I do thank you for your efforts.
                  Regards,  Fred
                  #13239
                  Ducky
                    @ducky
                      Hi Fred
                    You could try http://www.macsmouldings.co.uk he does fittings for all large scale boats and has quite a bit of stuff like torpedoes,hatches,and the like.
                    Hope this helps
                    Peter
                    #13242
                    Fred Gray
                      @fredgray24906
                      Peter,
                               Thanks for the lead. I have looked at Macs Mouldings and he definitely has some fittings that I can use and will order. The problem that I am having is that there are a number of suppliers for 1/24 fittings but they are WW2, the Perkasa is 1960 and the fittings changed after WW2.
                      Again, thanks for your help,
                      Fred
                      #4946
                      Fred Gray
                        @fredgray24906
