Good to hear from you Tim, long time no hear!
It is screwed down pretty tight as I broke the rules by having the servo side on and not helped with it being a small servo with only two screws, though I did put some timber along each side to limit movement. Not really a problem though as it's a slow moving boat and the forces are light.
You may have gathered from my previous post that it's sorted though now – see my build blog. I will loosen the screws off though and nip them up.
Are you building anything?
