motors
motors
Home › Forums › All things floating › motors
  • #17551
    Hugh Connolly
      @hughconnolly85056
      hi looking for help,my daughter brought me a ready to go r/c american custom boat when she was in usa ,but when i took it to our local model club pond it would not work when other boats in pond.so last week took deck of and stripped all elec,out going to put speed controller and other elec  in,my problem is the boat has in rudder it had two motors for steering i am putting in two new motors,how do i get motors to control steering, thanks
      #17553
      60watt
        @60watt
        Do you mean "no rudder" or in-board ?
        My transmitters allow me to unscrew and rotate the sticks by 90 degrees.
        Some transmitters can "mix" a throttle and rudder signal for the purposes of V-tail aircraft.
        You can get a device to fit between receiver and servos and another speed controller or drive two motors with one controller and fit a rudder.
        Tom
        #17554
        Hugh Connolly
          @hughconnolly85056
          yes i mean no rudder  sorry should have said that  the props controlled steering.i hade a servo .receiver and switch kit from other boat ,but as it  has no rudder i dont know if have to fit another receiver to work steering. thankstom
          #17555
          60watt
            @60watt
            You could fit a rudder  and drive two motors with a single speed controller.
            To control throttle on two motors you would need two speed controllers.Then get a transmitter that allows you to unscrew and rotate the rudder stick by 90 degrees to make two throttles OR do some surgery by adding resistors to mix the throttle and rudder sticks together (cost is pennies) OR use the mix option if the transmitter has one.
            Tom
            #17556
            Hugh Connolly
              @hughconnolly85056
              thanks tom been sitting looking at it again, i was thinking .adding two rudders servo ,speed controller. and two recievers one for each motor ,or is it one reciever and two speed controllers,one for each motor ,.hugh
              #17557
              mick
                @mick
                hiya hugh
                what sort of space have you got in your hull because i was looking at one in u s a  same boat i
                think  there is not a lot of room  in the hull you will probably have to put the small servos in and
                check on the set up for room for esc  and batterys  i would double rudder it as you said
                hope this helps mick
                #17558
                Hugh Connolly
                  @hughconnolly85056
                  thanks mick there is plenty room in hull when u take every thing out. wat would be the right setup,two speed controllers or two recievers.  cheers hugh.
                  #17560
                  mick
                    @mick
                     hiya hugh
                    it depends on the set up you require you can  get a single  speed controller now  that does the twin
                    motors i think astec electronics do it not sure of the price i  do a couple of my boats on twin shafts
                    and twin motors but run them on single speed  controller  but this depends on the setup you require
                    i have other boat s on twin esc but that is on 3 or four channel setup  as i said its all about price
                    you are willing to spend and different motors esc and radio you are useing if you go to your local
                    model shop they will advise you or better still your local boat they  are always happy to help if you ask
                    the members hope this helps mick
                    #17561
                    60watt
                      @60watt
                      Hugh,watt transmitters do you have?
                      #17566
                        All . Yes good question….Do we take it that the boat works fine on its own but when other bods turn up and use their radios does yours then play up ?    Ashley
                        #17571
                        60watt
                          @60watt
                          I meant by "watt transmitter?" did Hugh have access to an older Futaba or Hitec handset which would have meant the only extra expense is one additional esc and five minutes of his time.These handsets can be customised to make   right : throttle    left : rudder or two tank style throttles for steering by motor.
                          Tom
                          #17572
                          Hugh Connolly
                            @hughconnolly85056
                            hi ashley yes if other boats in water the one i have wont work,it is a boat ready to put in water,i only had it in water once,i have took every thing out of hull and hve empty hull now. cheers hugh.
                            #17573
                            Hugh Connolly
                              @hughconnolly85056
                              hi Tom r/c i have are HITEC 2CH.RANGER11, 40M.AND2CH,40M FUTABA,MEGA TECH 2PL. thanks hugh
                              #17574
                              60watt
                                @60watt
                                I’m sure one of these handsets will let you rotate the rudder stick by a quarter turn.
                                Tom
                                #17575
                                Hugh Connolly
                                  @hughconnolly85056
                                  thats fine tom iwill see how i get on thanks all for ur help,im not to bad at building but always seem to have problems with r/c fitting,cheers hugh
                                  #17578
                                  mick
                                    @mick
                                    hiya hugh
                                    i am glad you are getting on ok  and hope your build goes ok  what motors areyou going to
                                    use in the boat the originals or different  just being nosey let us know how it all goes mick
                                    #17580
                                    mick
                                      @mick
                                      hiya hugh
                                      if you have twin motors look up the p94 mixer at the http://www.action – electronics .co.uk it is a
                                      two to three channel mixer check it out  hope this is of help mick
                                      #17581
                                      Hugh Connolly
                                        @hughconnolly85056
                                        thanks Mick I will have a look at that aswell,i have one new 540 motor in box i was thinking of buying another as they are quite cheep. cheers hugh.
                                        #3286
                                        Hugh Connolly
                                          @hughconnolly85056
                                          us custom boat
