Magin One – how do i make it faster
Home › Forums › Beginners › Magin One – how do i make it faster
  • #10058
    Allen Dannfald
      @allendannfald45010
      I have recently just built and launched a Robbe Magin One and to be honest I am a little disappointed about its speed!. It is running 2x 7.2 volt batteries, its standard 700/12 motor but a Electronize FR15 ESC. Does anyone have any suggestions of what I can do to speed it up a bit. Cheers
      #10064
      Zdenek Bilek
        @zdenekbilek23040
        Having a 12V motor, it seems to me there is simply a lack of voltage…
        Cheers
        #10396
        DickyD
          @dickyd
          Hi Allen Robbe recommend a 710 motor and a 12v battery pack.
          What size prop are you using?
          #10400
          Allen Dannfald
            @allendannfald45010
            Hi,
            the motor is stock (think it is a 710) from the supplied power pack and i am running two 7.2v packs giving 14.4 volts.
            The prop was also stock. I say stock, as it came off last week and am trying to get a replacement.
            Any suggestions?
            #10401
            DickyD
              @dickyd
              Hi Allen are you using NiMH Battery Packs as these dont often like being wired in series. If your motors are the 710s they should work on 12v. As you are getting a new prop remember small props are often better than large for speed. My Robbe PT 15 has a Mtronik vision 600 motor and a 35mm 2 blade prop and it flies.
              #1329
              Allen Dannfald
                @allendannfald45010
