LULONGA STYRENE HULL
Home › Forums › All things floating › LULONGA STYRENE HULL
  • #102713
    jeffrey mundell 1
      @jeffreymundell1
      Ineed some help please
      i am building a LULONGA with a moulded styrene hul, but the decks are 1mm plywood and i need to glue the deck alround the edge of the moulded hull
      can anyone advised what glue to use
      many thanks
      Jeff
      #4832
      jeffrey mundell 1
        @jeffreymundell1
        #102716
          Hi Jeff,
          Rough up the plastic hull inside to make a key and use a good epoxy resin should do the trick ? others may have better suggestions ??
          Edited By Ray Wood 2 on 05/11/2022 16:08:38
          #102719
            Jeff – if you can, it would be a good idea to glue a small section timber to the hull for the deck to sit on and provide a bigger and better gluing area as 1mm is very thin. As well as Ray's suggestion for glue I've been using Deluxe Materials Canopy Glue which glues different materials.
            Everbuild Stixal (which is a building adhesive and sealant) has been recommended by others and is a good price.
              I agree with Chris, fit a thin strip of wood glued round the hull just below deck level for the deck(s) to sit on. For the straight sections you might be able to use 6mm square. Something more flexible or a series of blocks aroumd the curved bow section. It is also a good idea to fit cross beams as well in places where they don't restrict access to the interior as they will support the deck across the width of the model. All this will help strengthen the hull.
              Whichever glue you use, as Ray says, roughen up the surface of the styrene hull to provide a mechanical bond.
              As a belt and braces suggestion, once the deck has been glued in place, run a little Deluxe Materieal Superphatic glue around the joints. This is very thin and will 'wick' into any cracks. Although usually used for timber to timber joints it also provides a good bond betrween porous and non porous surfaces including wood to plastic where it is surprisingly effective . I use it all the time as a little goes a long way.
                I totally agree with all the suggestions above………spot on.
                #102749
                jeffrey mundell 1
                  @jeffreymundell1
                  many thanks to you all,i have taken all the advise you have given
                  regards Jeff
