How to add photos to your posts
Home Forums Adding Images to Forum Posts How to add photos to your posts
  • This topic has 15 replies, 3 voices, and was last updated 12 months ago by Len Morris 2.
  • #118634
      In response to member queries the following extract from the FAQ section is a reminder on how to add images to your posts.
      How do I post photographs on the forum?
      You can add up to 12 photos to your post reply, these can be uploaded directly from your computer or phone in the post editor. Press the photo icon at the top of the post-reply box. You can also enter the URL of any photo on the internet to embed an image. Please note there is a 8Mb maximum file size restriction. Mobile is in beta mode and you may need to rotate your phone to landscape to see all of the upload options. Please note that images with an apostrophe in the filename won’t upload.
      #118640
        I did discover by accident at one point that there is also a limit to the length of the file name.  I don’t know if you can find out what the limit is Colin or whether we should all just be aware of the fact that there is a limit.
        #119049
        Len Morris 2
          @lenmorris2
          The limit on Windows 10 is 256 characters.  It can be extended by going into the registry.
          Len
          #119050
            That’s not what I am referring to Len.  There is a limit on the length of the file name that the picture database can accept for the forum.  This is nothing to do with Windows it is obviously the length of the field in the database that the forum uses for picture storage.  That limit is significantly less than 256 characters.  I discovered this once when trying to upload a picture and the system would not accept it.  I eventually tried reducing the length of the file name and it worked fine.
            #119055
            Len Morris 2
              @lenmorris2
              I suppose we await a reply from Colin. 🙂
              #119056
                I did send the webmaster a note but no reply. I don’t think it is worth worrying about, images should be supported by text and not need long names.
                  I only posted the comment so that anyone who may be wondering why thier picture will not go into the gallery when everything looks to be OK with it might be caught out by a long file name.  I don’t think we need to do anything about it, just be aware.
                  #119153
                    Just had a belated reply back from Andy, see below. I think it is self explanatory.
                    Hi Colin,
                    Sorry for the very late reply, I missed this email in my inbox somehow.
                    Technically there isn’t, however longer names can cause issues with some plugins as well as SEO.
                    Ideally they would be below 65 characters, but I would try and keep it as low as possible. Also, the character count adds to the overall URL, so the domain, plus the folder(s), plus the filename, and again that can cause issues for some plugins and database records if that gets too long.
                    What it doesn’t like is special characters or spaces, this can cause issues when the filename is sanitised, also capital letters can lead to future compatibility issues.
                    Good SEO usually means the filename would be relevant and unique also, so lots of files called image1.jpg isn’t idea, usually changing them to something relevant to a post or article helps, so something like model-steam-powered-boat-mar24-1.jpg, model-steam-powered-boat-mar24-2.jpg etc.
                    So in an ideal world:
                    -Lower case,
                    -No spaces
                    -No special characters
                    -Avoid really long filenames
                    WordPress does a good job of working with most filenames thrown at it, but the plugins that run over the top of it aren’t always as forgiving, so sticking to the above will help prevent issue when uploading, and with future compatibility.
                    Cheers,
                    Andy
                    #119155
                    Len Morris 2
                      @lenmorris2
                      Hi Colin,
                      Thanks for the follow up.  It made me smile!  I’m sure “Self” now understands everything.  As for me it was as clear as mud!  Not that it matters.  Never had a problem with the new system and it’s much quicker.
                      Len. 🙂
                      #120983
                      Len Morris 2
                        @lenmorris2
                        Some posts are now including short videos.  Brilliant but how is it done?
                        What does the file format and size have to be?
                        Do you still use the ‘Insert Image’ button?
                        Len.
                        #120993
                          Len, The way I have done it is to upload the video first to my account in YouTube, then simply insert a link from YouTube into the post on here.  This seems to be a fairly common way of doing it.  YouTube is fairly straightforward to use but, if you are having challenges, ask away.
                          #120994
                          Len Morris 2
                            @lenmorris2
                            Hi Richard,
                            I know how to post on You Tube and insert a link.  Some clever chaps on here however seem to be posting the the opening frame of the video directly, just like a picture, and apparently without any need to insert a link .
                            Len.
                            #121002
                              I think the picture is the link Len. Seen this on another forum, you insert the link and the forum software recognises it as You Tube and substitutes the opening frame for the link. I’ve not tried it on this forum though.
                                There are two ways of embedding a video.  First just go to your clip on YouTube in Your Videos, then copy the link that is written below it.  Click the ‘chain’ icon, second from the right hand side at the top of the posting frame, then click on the gear wheel at the far right if you want to put a specific title for the link.  Paste the copied URL into the field and close.
                                And you get this:
                                Richard’s Engine.
                                If however you want a picture to appear in the post then simply post the copied URL from your clip in YouTube directly into the post you are creating.  And you get this:
                                As Colin says, the picture is the link.  Double click and it takes you into YouTube, single click and it plays it in the post window.
                                #121011
                                Len Morris 2
                                  @lenmorris2
                                  Thanks Richard.  Option 2 is exactly what I was looking for.  Just need to make mi video now which hopefully will be mi Puffer sailing today.
                                  Len. 🙂
                                  #125899
                                  Len Morris 2
                                    @lenmorris2
                                    Just to say happy birthday to this theme and stop the first entry under forums being a year old.  Colin might consider archiving this.
                                    Len.
