HMS Dido
HMS Dido
Home › Forums › Beginners › HMS Dido
  • #13078
    Roy Cooke
      @roycooke76003
      Think my wife has great faith in my ability as she bought me a set of plans for HMS Dido.  Now that is very commendable of her but as I have never built anything like this before I am completely out of my depth.
       Could anyone recommend an idiots guide book that I could purchase to work my way through these plans and put an engine/remote control in please.
      Thanks
      #13107
      Grumpy
        @grumpy
        Hi Roy,
        Not a lot of information to go on here.
        My initial reaction was to ask where your wife obtained the plans from and how detailed are they.?
        Are they a fully detailed set or a less detailed model makers set.
        Also how big will the completed model be and do you have any experience in model making or woodworking.
        Grumpy
        #13117
        Roy Cooke
          @roycooke76003
          Thanks for the response.  I can probably deal with the plans and were bought from a website (this one I think), think I would like a book that will guide me through terminology etc.
           The completed model should be about 4ft long, have built a couple of models in the dim distant past but never from scratch.  I used to be an engineer until retirement.
           Roy
          #13122
            Hi Roy
            As an ex engineer you should have no problem in building a model boat. Do you have any experience in using wood as building material?
            Roy Cooke
              @roycooke76003
              Not a lot I’m afraid. I’ve looked again at the plans this morning and the things I do not understand is putting in the engine etc.
              #13129
                Hi Roy
                If putting in the engine is all that you don’t understand then you should have no problems building this model.
                Does your plan show the position of the engine?
                If so all you have to do is keep the engine shaft in line with the prop shaft to eliminate any shakes. All the other ancillary bits such as battery, receiver etc can be placed within the hull to suit ballast and trim i.e. wherever they fit best to suit the look of the model when in water.
                Bite the bullet my friend and enjoy the build.
                If you come across a problem there are lots of us on this site that are only to willing to help with advice based upon practical knowledge.
                All the best for the build
                Grumpy
                  @grumpy
                  Hi Roy,
                  Firstly I would suggest a visit to your local library to see what books they have on model boats.
                  Next you could try MyHobbyStore.com and see what they have to offer.  Traplet Publications also have assorted books on model boats and may have the one you need.
                  Have you considered joining a club as it is always easier to have something explained face to face rather than on a Forum like this?.
                  On a final note and, purely guesswork here, it sounds to me as if the plan is one of those by Glynn Guest.  He has had many plans published in Model Boats over the years and they all follow the same pattern of simplicity and ease of building.   A copy of the building article which accompanied the plan should make things a lot clearer.  I would suggest that you contact the Editor of Model Boats to see if you can obtain a copy of the article.  Even if you cannot get the original article, any article on building one of Glynns designs should provide enough information about the engine and radio control installation for you to complete the model.
                  Grumpy
                  #13251
                  The Long Build
                    @thelongbuild
                    Hi Roy
                    Have you checked out Model warships Uk  http://www.modelwarshipsuk.co.uk
                    I have attached a direct link to the HMS Dido Build Thread, you may have to join to see the pictures..
                     http://modelwarshipsuk.informe.com/forum/hms-dido-dt319.html?highlight=dido
                    I am sure you will find it worth while..
                    Larry
                    #13256
                    Roy Cooke
                      @roycooke76003
                      Thanks to everyone for their help.  I have made a start and as someone else has mentioned, the plans do not always run true.  Might take me a few years but I will get there.
                      #13257
                      Andy Hustler
                        @andyhustler32076
                        Good luck with it Roy i wish you all the best of british.My 1st boat was a Perkasa MTB and like you i had’nt a clue but after laying all the bits out and reading through the instructions i managed to make a 1/2 decent job of it and am now,amongmost many other things,renewing the stanchion rails and torpedo holders.as Paul and Grumpy have said shout out theres always some one out there willing to help and esp your local model club be it an Engineering club or Model Boat or even your local model shop.Also theres the Surface Warships Asociation they have a website and you may even find some one local to chat to or advise.Good luck and happy sailing ,many best wishes Andy
                        #1557
                        Roy Cooke
                          @roycooke76003
