Help with motor control
Home › Forums › All things floating › Help with motor control
  • #13421
    Graham Brooker
      @grahambrooker43674
      Hi All
      Can someone advise how if it is possible control two Speed 600 eco’s individually from Futaba Field Force 6 Transmitter, coming from planes to boats i am not so familiar with the electric side of things.
      Graham (Essex)
      #13433
      Manxman
        @manxman
        Hi Graham,
        Not familiar with your particular transmitter, but can not see why you would have problems.  Assuming you have two control sticks both with horizontal and vertical movement (4 of your 6 channels).  Then just run each motor from each of the 2 vertical channels.  Each motor will require its own speed controller.  If you are intending to use the BEC feature, ensure you use only one and disable the other (usually requires the power cable to be removed from the plug – be sure to read the instructions that come with the ESC).
        If you go to the Gallery – page 11 – and load my album "Le Caux" you will find a wiring diagram which should cover your needs.
        Cheers – Ken
        #13437
        Graham Brooker
          @grahambrooker43674
          Hi Ken
          Thanks for your info, i have done some more research, also looking other forum answers to other similar questions i have looked into useing motor mixers controlled from just the throtel stick, reducing the port motor in a left hand turn ect. i am off to look at "Le Caux".
           Cheers Graham
          #3206
          Graham Brooker
            @grahambrooker43674
