ferrite cores
ferrite cores
Home Forums R/C & Accessories ferrite cores
  • #5077
        Whilst in Maplin`s on Saturday, I spied a shelf with ferrite cores on. And bought some. About 20mm long with a 2mm(ish) hole in them.
        I know they have been mentioned in the past as another item in the arsenal of anti-interference measures one can use, but where is the best place to fit them??
        I  don`t have much of a problem, but for instance the Sunderland or the LCM have all the radio stuff tightly knitted (literally!) together due to lack of space, and sometimes I get a bit of interference which is diminished by moving said components about..but if i had some ferrite`s??   would it help?
        They are so cheap i thought it may be as well to give it a try. Suggestions pu-leeese
          Herewith are Chapter and Verse from a Teccie Demi-God:
            Dave, thanks for that, i will surf and inwardly digest.
