Exmitter EX7
Exmitter EX7
Home › Forums › R/C & Accessories › Exmitter EX7
  • #106113
    steve clark 6
      @steveclark6
      Hello Modell Boat forum, new recruit here needing a bit of help with the above.
      I have the Exmitter 7 and 3 receivers which I bound in as stated in the manual . Throttle , rudder and Aux for lights were working fine
      I then tried to test the failsafe feature by turning on the system then turning off the transmitter to cut the signal. The motor just revved very high until I turned the TX back on again very quickly. I thought it was meant to return to zero on the loss of signal
      So what am I doing wrong?
      I have tried to Re bind the receivers again as per manual but the bind light does not blink on them to suggest its re binding and nothing changes with the operation of the set afterwards. I have also tried RESET to no avail.
      Can these be re bound? If so, how, and will all settings return to factory default settings.
      Many thanks for any help
      Steve C
      #5664
      steve clark 6
        @steveclark6
        Binding query
