elictric motors
elictric motors
Home › Forums › Beginners › elictric motors
  • #11016
    John Harvey
      @johnharvey28677
      Hi can you help …….. i have built a monster boat at 2.1 mtrs long …its based on a sealine motor boat with fly deck……..i need to know what engines  would be good for this….electric motors are what i had in mind but i need 2 with a lot of power
      The props are 11inch and the blades are 75 mm  thanks jh
      #11056
      Paul Millers 1
        @paulmillers1
        John,  you could try Phil Locke. Phil and his mate Ian rework buggy motors to run off 36v for the speedline 1/12 scale Severn Life Boat, I have just purchaced a pair for mine. There is a vidio of his Severn on 48v going at a hell of a lick, hope this is of help.
        #11085
        JC Uknz 1
          @jcuknz1
          You could also look at windscreen motors off older cars which will work off 12v batteries, freinds I know use the 7.2Ah batteries that I use to power their boats … we recycle the batteries rejected by communications gear.  Some [most] are AOK for model use.
          If you want to go petrol then there are the weedeater motors [30cc and 22cc]which we use to power our quarter scale jetboats but you would need a gearbox to split the power into the twin props?  Our boats when properly tuned go faster than older members can handle
          #11099
          John Harvey
            @johnharvey28677
            thanks for that  i will look into it  i will get in touch if i get stuck  thanks again jh
            #1399
            John Harvey
              @johnharvey28677
