electrics
electrics
Home Forums R/C & Accessories electrics
Viewing 21 posts - 1 through 21 (of 21 total)
  • #16200
    EJ
      @ej
      I would like to advance my boat building.  Me and electrics do NOT mix.
      I need the skill to use two motors in the same boat. But have had no succes so fare.
      I need a clear couloured wireing diagram to work from. Is there any available on the market. Can anyone help me on this one please.  I have searched the mags and adverts for books, but can not find what I am looking for.  I am now on my fourth airboat and one motor is begining to feel a little slow!  I have experimented with gear boxes and props.
      E-mail if poss;  [email protected]
      Thank you.
      #16201
      60watt
        @60watt
        There are limitless posibilities.
        More info like what motors,batteries and RC gear you are using just now would help.
        Tom
        #16204
          EJ. Assuming you are talking airboats and not ordinary floaters here,  Brushless is the thing to use for this, and usually coupled with, gulp, LiPo batteries. I should think there is not much corporate knowledge of such an animal on this site, I have a feeling that a model aircraft site may have more experience of things air propellery. Mind you, I suppose they wont then have ANY experience of airboats !  I am not certain but I think a twin engined, and by this i take it that you mean two props airboat is almost certainly going to need handed props, to stop torque reaction twisting the thing over, at least on startup and quick changes in motor accelleration. A model aircraft may dip slightly in the air but a boat stands a good chance of flipping over, or at the very least veering badly off course (and then tipping over). ….and depending on the projected size I am not sure there is a big choice of props in this regard. Is yours a traditional flat design (optional action man) or are we talking cutting edge, er, something else?? And what sort of size/weight.   Ashley
          #16225
          EJ
            @ej
            For 60W.
            Thanks for your conrtact, here is the info you requested..i hope
            weight; under 1 kg   (900g)
            L     45cm
            W     224cm
            D     5cm
            Motor 545;   7.2V  Ni Cad;     TX Hitec Laser 4;     RX Hitec 6 ch;     Servo Hitec HS323 HDorHs 55 mini.
            My first airboat was coppied from the Glynn Guest plans and was an immediate success.  Since then they have just got bigger and faster, great fun.  Where will it all end…I blame Glyn..
            Thanks v/much..EJ
            #16226
            EJ
              @ej
              Thanks for your reply Ashley,
              So much to ponder and very interesting too.  All the info will be studied and read in conjuction with the artic in the latest ModelBoats Mag.
              Mine are the traditional flat type with push props..(w /action man)..
              L/45cm; W/24cm; D/5cm.  545motor w/7.2V Ni Cad.
              I think I can atually see through the top of my blindfold!!.   I am new to this hobby and find it very intersting, sos thank very much for your reply.
              Regards EJ.
              #16235
              60watt
                @60watt
                Hi EJ,
                Are you using a single BEC speed control – no Rx battery – and two motors ( 1 or 2) wired in series?
                Tom
                #16241
                Len Ochiltree
                  @lenochiltree67043
                  Hi EJ,
                  Check out Novembers Model Boat Mag in it is a Air Boat with Brushless motor and ESC,NOT cheap, the prices make me come over all funny!.
                     Len
                  #16269
                    Ditch the action man, use a Barbie; much lighter, more streamlined  = more speed. Ashley
                    #16304
                    EJ
                      @ej
                      Hi len, thanks for the contact. Yes I got the Nov MB and it make for good reading, I need to study it more carfully and  mabe rethink some of my storming ideas!!.
                      EJ
                      Tom, No RX bty and hope to use 2 motors eventually, tho with all the info now received I may  have to rethink and stay with single motor set up. It will come withing my limited knowledge of electronics,we shal see.
                      Thanks for that EJ.
                      Ashley,  A Barbie Doll!!!…Blond!!. I see the point tho. BUT don’t you just loove the ripples on the Action MAN.  Ha Ha.
                      Thank Ashley.
                      A visit to the model shops in Scarborough today may well see me home with some guddies!
                      Cheers all EJ
                      #16305
                      60watt
                        @60watt
                        Hi EJ,
                        You said one motor was running slow.
                        That is why I asked…
                        ……..what motors,batteries and RC gear you are using…………
                         Tom
                        #16309
                        EJ
                          @ej
                          Hi Tom, I think I may have confused the situation a little with my initial writings.
                          Here is my setup as it stands.
                          400 motor; motronic marine 25 ESC;  7.2V Ni-Cd 1900 bty;   Pusher prop 7ins. I had started experiments with two by 400, not very succesful.  Then I am about to try  545 MOTOR  for more push on its own.  I am not using seperate bty for the RX.  I have to say that my initial builds have been quite good and responsive and good to handle.  I just want to go that step further or am I running befor I can walk. Anyway all donations greatfully accepted from all you kind gentlemen. Thank you.
                          Regards EJ.
                          #16310
                          Len Ochiltree
                            @lenochiltree67043
                            Another thing to think about is whether there are speed restrictions on your water? before you spend oodles on gear.
                               Len.
                            #16312
                            60watt
                              @60watt
                              Hi EJ,
                              I’ve got the picture now.I have seen the  ready-to-run versions.
                              The wiring should be a piece of cake. I have two diagrams from my esc instructions which shows a single motor,esc,battery and receiver.It will make a big file so I will upload it to a file sharing site and send you the URL.
                              I suppose you want to save weight and also get as much power out the motor as you can.
                              You say you have experimented with gears and props so you may understand the prop torque,motor rpm and power chart of your motor. If not look at this link . If you don’t understand any part of it then ask.
                              It doesn’t go into the merits of props but shows you how to deliver the maximum power to a prop i.e. for a given voltage you want to aim for a prop which will slow the motor to half its no load speed.
                              Use your rpm or current measurement to hit point A for maximum power.You can then further increase power by increasing the voltage.The power loss at A is 50% of the Volts x Amps you feed into the motor.
                              Assuming you don’t run at revs that require ballraces,the motor power rating is in losses(not voltage) and is down to material temperature limits temperature of the cobalt magnets,enamel winding insulation and plastic commutator insulation you can see through the holes. You will see maximum power figures for 400(27 dia) and 540 and 600(35 dia) sized motors on the Johnsonmotor website.
                              The power ratings of ones with internal fans will be higher down to the fact they will tolerate higher losses before the hotspot reaches its design limit.Watch though,because these are designed to run at high rpm and they will have a low torque/current ratio.
                              Easy if you did it for a living.
                              #16320
                                EJ. You need to speak to a good model suppliers that deals in aircraft. The science of matching motors,gears and props is well known to them . You are running direct drive props, there are loads of diferent types to choose from and it may be that a simple change of prop (make,pitch and profile or even a three bladed one) may get you all the speed you want with the existing motor.  Ashley
                                60 Watt, How do you measure the rpm of an electric motor?? is there an easy way??  Ashley
                                #16321
                                60watt
                                  @60watt
                                  ashley needham wrote (see)
                                  The slide rule generation use a spindle type unit which you can locate by searching rpm meter and so on.That device engages a clutch and counts the revs on a dial for a given time.That was the thing I used when working in cramped confines.I only ever used that at 3000 rpm max and with big powerful motors so it may influence a385 or the like.I suppose the best way is to use search engines to find an instrument like that for sale.
                                  These are remote sensing without that drawback………
                                  I’ve had a few frequecy meters over the years and used a photo-transistor+resistor and painted a white line on my motor coupling.
                                  If you have a spare £60 you could get a multimeter from Rapid Electronics or other electronic suppliers to do the same thing.
                                  An oscilloscope does the same job but you need to eyeball it and have the same two components or ahall sensor and know where to stick it.
                                  If you work in a school,college or business concern there is bound to be something else I’ve forgotten.Any instrument is as good as the person who uses it.
                                  Electronic magazines and websites are full of crude and simple frequency instrument projects so you may find something suitable for veroboard and use mains frequency as a reference (not mains voltage!!!) I’ll have a look see.
                                  Tom
                                  ps For a rough idea you can use current ,as long as you are flat out or have a true rms meter.You can get a motor stall current at low voltage and back calculate but it’s tricky to measure and make sure your voltage is constant without a regulated high current supply capable of running a motor.
                                  If you are agile you can manage that with one meter,batteries and your motor.
                                  #16323
                                  EJ
                                    @ej
                                    Len, good point on the speed restrictions.  We only have a small private lake, 80 X 35 yards with a small island in the middle. Grass bank down one side and stone wall with steps down the other.  We only have three people at the moment and we all enjoy it on Sunday mornings. Oodles of money we have not so spending needs to be thought through befor we go shopping.
                                    Reminds me, I need to put my battries on charge.  I have two boats on the water, one half completed and now building another airboat to replace the one damaged beond repair.  That will no be a long problem as put in all the info and advice given by all you very kind people.
                                    Cheers, EJ.
                                    #16325
                                    EJ
                                      @ej
                                      Ashley, Len and Tom.
                                      Thanks so much for all your help.  I am now going to pickout all the information I need. Then get on with the disign of the replacement airboat. I have loads of time, retired, now I have the knowledge I can put all my "bright ideas" onto paper and then on to the bench.  You will be the first to know.
                                      My problem is the lack of private transport.  So local sailing at this point is all I get.  The two others are always ready with offers and we hope to get as far as Scarborough and York in the future.
                                      Any more info is always welcome.
                                      Cheers for now EJ.
                                      #16335
                                      Mike Davidson
                                        @mikedavidson22772
                                         I don’t know,you lot are your own worst enemies, you talk of bec speed controllers LM 2940’s and 7805’s, but I don’t think you realize, they are all precisely the same thing . The ESC with a bec  probably uses am LM2940 or a 7805 chip to provide the positive supply to the radio/servos, and you can do the same more reliably using either of the two chipsmounted anywhere convenientand running a red black pair of wires to the battery socket on your radio. if anybody wants to make their own battery elimination circuit just tip me a nod and I will give you the pinouts of the devices   .it is dead simple as long as you make a common negative to all parts of the circuitry, I might even do the same myself, that will make a bit of space when I take the receiver battery box out of the model
                                                 IS there anybody left that is still confused??????????????????
                                        PM meand I will tell     MIke  D
                                        #16343
                                        60watt
                                          @60watt
                                          Ashley,.
                                          You had authorship of the five latest posts until I put this up!
                                          #16377
                                          EJ
                                            @ej
                                            Mike D
                                            In reply to yours.RThis is what I have to hand.
                                            2 X  Graupner speed 400 motors;   2 X Mtronic 25 amp ESC’s;   2 X  Batry packs,7cell NI- mh 8.4v 100mAh;   6 channel RX and Hitec 4Chl TX.
                                            I also have 2X 545 motors, can I use these also?
                                            There is so much on offer and I could buy Artf, including all the gear!!.  BUT I would like to build and fly instead of Buy and fly.  The same as I have don with my boats.  Buty the main thing for me is I would like to be able to move on to two motors.  Sound like real fun to me.
                                            Thanks Mike D, regard EJ.
                                            #4999
                                            EJ
                                              @ej
