Digifleet charger output
Home › Forums › R/C & Accessories › Digifleet charger output
  • #10473
    Mike White
      @mikewhite31395
      Hi, Does anybody out there know what the voltage output from a Digifleet Nicad dual output charger should be?.. Both of my 25 year old chargers voltages are around 25volt on the rx and tx connections. My Futaba dual output charger gives 22volt tx and 4.8volt rx. The nicads are all 4.8 and 9.6 packs.
      thanks
       Mike
      #10488
      Ian Weston
        @ianweston57171
        I don’t know what the oputputs should be but if its any help the offload outputs from my Digifleet XPFM charger are 16.3 volts TX and 15.9 volts Rx. It works fine charging my Fleet gear and I used it last week to charge a 1500 ma/h Tx battery from a Graupner Mc10 I had just bought – it did take a long time though! I’m fairly sure that the power output of the unit is 50 ma.
        #10489
        Mike White
          @mikewhite31395
          Hi Ian, Thanks for this, I check my voltage meter and replaced the batteries in it, I am now getting a more realistic reading of 15.5 volts which compares favourably with yours.
          thanks again
          Mike
          #4917
          Mike White
            @mikewhite31395
            High voltage
