I have two 7.2v 4200 mah NiMh connected in series to drive a brushless motor through 30Amp ESC. This comfortably powers a water jet drive at an excellent RPM.
I now wnat to power two water jet drives using two brushless motors and two 30 amp esc. No problem.
However, will there be a problem if I connect two 7.2v 3800 mah NiMh in series and then parralel them with the 4200mah?
I know that this is not possible with LiPo’s.
regards
