Calling Harry Smith 1
Home › Forums › All things floating › Calling Harry Smith 1
  • #102920
    Rich Griff 2
      @richgriff2
      Calling Harry 1
      Sir, your name has been mentioned in "fragile plan" thread regarding a pdf sea Commander plan ?
      I know Tony would appreciate a copy as would I, and others….
      Could you help ?
      Over…..
      #4836
      Rich Griff 2
        @richgriff2
        #102921
          Hi Rich,
          I have emailed Harry, he's down under and is probably running his boats, as it's summer down there
            Yes, soon he will post pictures of him and his mates in shorts and tee shirts boating in 30 degrees of heat on the travel brochure bit of water he calls a canal (not to be confused with a grotty canal in Birmingham) and after at the Barbie (not to be confused with a popular fashion doll).
            Harry has loads of pdf’s. He is the pdf king.
            Ashley.
            #102929
            Rich Griff 2
              @richgriff2
              Thank you so much guys
