Brushed or brushless
Home Forums Beginners Brushed or brushless
  • This topic has 12 replies, 7 voices, and was last updated 9 months ago by Chris Fellows.
  • #122569
    cheddar24man
      @cheddar24man
      Still totally confused regarding brushed/ brushless motors.
      Model is a 38″ MTB weighing in at just under 1Kg.
      I’ve been recommended to use a brushless 3536-8 1050K motor with suitable 40A ESC. These come in at over £50 for the pair.
      Would a compatible brushed motor with its ESC come in cheaper? I presume I can use LiPo batteries with either motor type. I’m not too worried about it leaping around the pond!!
      Charles Oates
        @charlesoates31738
        Stick with brushless, much more efficient so your battery will last longer than an equivalent brushed motor. I doubt you can make any saving with a brushed motor, a 40 amp speed controller on its own will be around 40 quid for a decent one.
        The combo you’ve been recommended seems perfect to me, i use a very similar set up myself.
        Charles.
        #122628
        cheddar24man
          @cheddar24man
          That’s thrown cat amongst pigeons as I’ve almost decided to go brushed with this combo:
          JOHNSON 683 BRUSHED MOTOR @ £9.99
          HOBBYWING QUICRUN 1060 WATERPROOF BRUSHED SBEC ESC (60A) @ £23.49
          The brushless I’ve been quoted with similar spec:
          3536/08 1050KV Tornado Thumper V3 Brushless Outrunner @ £26.99ZTW
          Shark 40A SBEC ESC G2 @ £24.75
          £30 vs £50 so quite a good save me thinks. This is, after all, just a hobby and as an 86yo pensioner £20 is aa lot!!😎
          #122629
          Dave Reed
            @davereed72029
            Suggest you wait for more recommendations before spending money – there will be people out there with similar size boats who can comment on the power system they use.
            The 683 brushed motor will probably be about 100w with a 3S LiPo, not a lot of power for a boat that size.
            There are brushless motor/ESC packages out there of around the same power that can be had for around £15. They are intended for aircraft so you don’t get reverse. Get the cat some more pigeons! A search for “2212 and ESC” will likely find some. However, build quality of these can be variable.
            My personal recommendation would be to go for the brushless Tornado/Shark combo, otherwise you may end up spending more money upgrading later.
            Dave.
            #122630
            Charles Oates
              @charlesoates31738
              Those motors aren’t comparable in performance at all. The brushless motor is very much more powerful. Whether the Johnson would be enough for you in a 38 inch mtb, only you can decide, for me it wouldn’t. I understand the need to be sensible with the cash, I’m not far behind you in age, but 20 quid isn’t much as a proportion of the whole build. Your choice im afraid, hopefully you’ll get some more opinions before deciding.
              Charles
              I meant to add that most people who run fast scale models have gone over to brushless motors, a quick search for rttl and sea comander and perkasa models will give you some guidance.
              #122631
                I would be inclined to go down the brushless route too. An MTB is meant to look like a MTB and not an overpowered canal boat!
                Ashley has some experience in getting performance for good value, perhaps he has some suggestions.
                cheddar24man
                  @cheddar24man
                  OK guys, I get the message! Stop being a skinflint and go brushless🤣🤣
                  #122640
                    I think the best advice is try to find someone with a similar size and shape hull and see what they have installed.  You can’t beat someone else’s experience.
                    #122644
                      I think Charles in his earlier post has confirmed the recommendations of SLEC with their kits of fast models of a similar size. I am all in favour of brushed motors for conventional scale models as giving economical performance at reasonable cost but, having built a couple of the Dave Milbourn designed Fairey powerboat kits, I am convinced that for this type of model the brushless motor offers an unbeatable combination of performance and efficiency. There is no way my models could have performed as well with brushed motors.
                      As always, horses for courses.
                        Brushless.
                        We use cheap and cheerful 28mm outrunners at the pond. Most of them develop well over 120 watts on 12v (3s) and a motor/esc combo, unfortunately forward only, can be had for under £20. The motor will weigh about 1/3 the weight of a 600, a performance boost in itself.
                        For those that think a 28mm is too small, well a couple of mine (can’t remember make offhand) can develop 160 watts on a 3s and will spin an S40mm two blade prop all day, and 1Kg is not a heavy boat.
                        If a few extra quid can be found then obviously a 35mm motor would be better as there’s more turning effort to be had by a larger diameter motor and the best performance would likely be obtained with the recommended 35mm setup, but as usual it depends on how fast you want to go and how much you want to pay for that performance. The 28mm motors beat a 600 in almost every department.
                        A wattmeter is invaluable here. A very cheap addition to the toolkit and very useful for checking the load on a motor, and telling you how many watts it is producing so you don’t overload it.
                        <p style=”text-align: left;”>Just as an aside, the 1000Kv unbranded motors we use have shown they can turn an X50 prop with only a small overload on their maximum current draw, however you wouldn’t want to run one like this for fear of overheating, however a brushed 600 would simply melt I reckon with a load like that.</p>
                        Charles Oates
                          @charlesoates31738
                          Ashley is bang on with the 28mm 1000kv motors, I’ve one in my 1 meter long rttl, bags of power if i want it. Currently you can get them on amazon from about 18 quid. I’d not suggest the higher kv motors for most models, 12000 revs on 12 volts is about right. I’d hope you can find a similar deal from a model shop though.
                          Charles
                          #122653
                          cheddar24man
                            @cheddar24man
                            #122706
                              Yeah, had to be brushless really. Good choice with Overlander, I use them in nearly all my builds.
                              I still can’t get my head around how much power these little motors produce and tend to over motor my models. Not a problem, other than more expense as the bigger motors tend to have lower kv anyway and the performance can be governed by the battery choice.
                              What ESC are you using?
