Blow torch
Blow torch
Home › Forums › Beginners › Blow torch
  • #12296
    peter penton
      @peterpenton38479
      have an old flamemaster air and gas torch designed for town gas ,does any know how to modify it so I can use bottled gas?
      #12299
      Len Ochiltree
        @lenochiltree67043
        Hi Peter,
        Your local Calor gas / Caravan Show room may be able to help, but I suspect it would be more costly to convert than to buy a bottled gas torch.
                       Len.
        #12301
          Peter
          To adapt for bottle gas you will need to change the regulator and the gas jet. I suspect that the jet in your flamemaster will have an imperial thread whereas the modern jets are metric so be prepared to do a little engineering work to make it work.
          peter penton
            @peterpenton38479
            Thanks Len  & Paul
            looks like I have to do some research or trial and error could be fun ?
            Peter
            #1500
            peter penton
              @peterpenton38479
              Flamemaster
