Battery connection
Battery connection
Home › Forums › R/C & Accessories › Battery connection
  • #76672
    Ian Carter 2
      @iancarter2
      I have recently purchased a Flysky i6, stupidly forgetting to purchase the battery for the receiver. Just goes to show how much I thought things through. Doh!
      Need to buy the power and have looked on Component shop, they request the battery type connector I require, can anybody advise.
      #5519
      Ian Carter 2
        @iancarter2
        #76674
          You'd be best advised to buy a wiring harness which includes a receiver connection, a switch, a battery connector and possibly a charger connector as well. This one should do the job **LINK**
          A battery pack with a Futaba 3-pin connector will fit **LINK**
          Kev.W
            @kev-w
            If you get one with the JR/Hitec connector, it will save you having to slice off the guide fin that the Futaba version has.
            Fly Sky recievers don't cater for the Futaba fin.
            #76676
            Eddie Lancaster
              @eddielancaster
              If the receiver for the Flysky i6 is the same as mine there is no case, it is just pushed into a plastic sleeve and the pins are vertical at the end of the sleeve, so either plug will fit.
              Eddie.
              #76677
              Ian Carter 2
                @iancarter2
                One further question, could you advise on the correct battery charger I would need for the batteries shown on the link? thank you for the advise so far.
                #76679
                  Depending on the project, is a receiver battery needed? If an ESC is involved, a lot of them have a BEC built in which provides a handy power source for the receiver and whatever else is plugged into it.
                  #76682
                  Ian Carter 2
                    @iancarter2
                    Malcom,
                    The equipment is for my Thames sailing barge, will be fitted with a sail winch and servo for the rudder. Surely you need a battery for the power supply.
                    #76684
                      Hi Ian
                      You will be fine with a 4 or 5 cell AA sized receiver battery for the winch & steering Servo's
                      Ian Carter 2
                        @iancarter2
                        Ray,
                        Appreciate that but the battery charger is the next obstacle.
                        #76686
                        Eddie Lancaster
                          @eddielancaster
                          Hi. again Ian, for my model yachts with 4 AA or 4 AAA cells I am using a Fusion NX 83 £9.99 from my local model shop, it will charge 4-8 NI-Cad or NI-MH cells, just plug it into the switch harness charge socket and wait for the red light to change to green, job done. It will also has a plug to charge a transmitter battery but the Flysky i6 does not have this facility, but it is there if you need it in the future.
                          Eddie
                          #76687
                            Strangely Component Shop don't do a standard plug-top charger for simultaneous charging of Rx and Tx batteries, as described above in Eddie's post. I've used a Fusion charger and they are fine, so the smart money is on that NX83. Cornwall Model Boats list it at £9.95.
                              Posted by Ian Carter 2 on 13/04/2018 19:11:58:
                              Malcom,
                              As said earlier, in the boat it just needs the 4 or 5 cell AA pack and a switch harness.
                              Using AA NiMH, both transmitter and receiver batteries will want to charge at the same (low) rate, but if the transmitter has 8 cells and receiver 4 or 5, obviously they are different voltages. If using one charger to do both at the same time, it will need to be a bit special. At least having a way of preventing the two batteries "seeing" each other.
                              Having spent much of my working life messing with electric bits, I had a tendency to knock my own together. I used a cheap battery eliminator from one of the cheapo chains with a current limiting high wattage resistor inserted into one of its leads. Add an appropriate connector, repeat with another eliminator for the other battery, result two overnight chargers. I can't be very specific, because I did them over 15 years ago and the memory has fogged and it just sits there and works. Low cost chargers often say quote their voltage and say something like "300mA". They rarely say whether they have a circuit built in to limit them to that maximum, or whether the components inside start to overheat at that point. Quite often, they are the £1.99 eliminator with a different label and higher price.
                              A write-up on the NX 83 (sounds rather more classy than the £1.99 eliminator) here – https://www.logicrc.com/reviews/OFSNX83_RCMW_052011.pdf – One battery at a time, overnight charging. One at a time should not be a problem – the transmitter, when charged, should last for several sessions.
                              #76690
                              Eddie Lancaster
                                @eddielancaster
                                Looking at the instructions for the NX83 it must have two separate charging circuits, the tx side will charge 4-8 cells, 4.8-9.6V at a constant current of 150 mA.
                                The Rx side will charge 4-6 cells,4.8-7.2V at 750mA with Delta Peak Cut-off, whatever that means, I am sure someone can enlighten me!
                                Eddie.
                                #76691
                                Ian Carter 2
                                  @iancarter2
                                  Thank you for your responses, think I'm settled on the Fusion NX83, looking at the batteries from Cornwall Model Boats list, there are two that seem to tick the box; P4405515, Receiver battery pack Nimh 4.8v 2100mah or P4405530, 4.8v 3300 nimh ENERGY- Pro battery pack.
                                  Reading a few threads, would I be right in assuming the latter would benefit in giving longer running time and if so is it that significant?
                                  #76693
                                  Byron Rees…(Ron)
                                    @byronrees-ron
                                    Ian,
                                    Yes..the higher the Mah rating the longer it will last. Check out page 7 in the new Component shop catalogue. These show the Low self Discharge batteries for infrequent or lower demand use.
                                    Their 2500 one at 4.8v is only £6.50 but you may have to order it with a new plug or fit one yourself, JR/Hitec type fits your radio. Also depends on how thirsty your sailwinch servo is.
                                    Should get a years sailing from one of them!!!
                                    Ron.
                                    #76695
                                      Consider mAH as equating to gallons in the tank. The more gallons, the further you can drive. With sailboats, practice helps. The more practiced you get, the less you have to do with the steering and sailwinch, the longer you get to sail before you need to recharge.
                                      Delta Peak – as I understand it, the charger offers the battery LOTS of current at rather too much voltage in short pulses. After each pulse, it looks at the voltage and when it considers that the voltage is not rising any more, decides that enough charging has happened, and stops. I regard my overnight trickle chargers as cheap, cheerful and reliable.
                                      #76698
                                      Eddie Lancaster
                                        @eddielancaster
                                        Thanks for that explanation of delta peak, although that is what I am using I do tend to agree with you that simple is best.
                                        Eddie.
