K40 Laser
K40 Laser
Home Forums Soapbox K40 Laser
Viewing 6 posts - 126 through 131 (of 131 total)
  • #96694
      Yes its a CAD cutty out thingy, more commonly know to grown ups as a CNC machine.wink
      It is for cutting and 3D sculpting Nylon for engine mounts, firewalls and servo mounts, I use Nylon as it is stronger than 3D Printer filament.
        Very interesting Paul
        Can`t wait to see it in action
          Hi Captain Bob
          Its only a small bed machine but its ideal for the bits I want to make.
          The machine came with an upgraded motor, a laser unit and a load of cutting bits.
            It will be interesting to see what you can do with it Paul.
            #96719
            redpmg
              @redpmg
              Be very careful with an unguarded Laser Paul – very dangerous to ones eyesight – at the very least have a sheet of yellow tinted Perspex between you and it and wear yellow goggles – unless its a fibre Laser in which case believe you use red………
              Always wanted a CNC router as well as the laser – not only cuts but contours too – they use the large ones here for producing very accurate scarf joints in plywood for boat kits etc. – amongst other things of course.
              #96721
                Hi Red
                Thank you for the advice, I got all of the safety equipment when I bought the K40 and follow a strict procedure when using the machine.
                This little CNC is just for cutting and contouring Nylon so the laser pack will stay in its box.
                The CNC will be linked in to the workshops extract system and as usual I will be using a P3 mask and safety specs.
              Home Forums Soapbox Topics
