I worked out the opening hours of the specialist shop for the veneers and luckily they had another sheet of the same. Fortunately not a grand fortune at 12.50 euros a slice and I will have some left over to try on other things.
Work on the boat did not come to a complete stop but have had little time for posting.
Going back to the sails, the original set cleaned up very well and are ready for use as above. These sails fit the mast that is scale length but this will be under canvassed in light weather so ages ago I made another mast but never got around to rigging it of making any sails.
These new sails are going to be made in 30 micron Mylar and because this material does not have a warp and weft like Dacron you cannot get any camber (curve) in the sail like one can with a woven material. The camber has to be built in using a sail block.
It is not immediately easy to see how this works and Larry Robinson's book is quite technical so I will try to explain it in simple steps because once you get there it makes sail making dead easy. At this size (and IOM at one metre) there is no need for any sewing.
Larry made his (and others do too) from two wooden blocks stuck together. Some use foam as you can find on UTube and some are fabricated. I don't have large blocks of wood and Larry's method of cutting the curves frightened the life out of me. Fabrication was the way to go as I don't have any suitable foam either and I wanted something much more durable.
The essence is that have two surfaces that are curved in one plane only and bring them together at a slight angle. This give the third dimension to the sail panel and the camber that we are looking for.
On a small sail is may not be necessary. Much of the camber of the sail can be achieved by slackening or tightening the outhaul. Even on large sails a significant proportion of the draft is controlled be the outhaul but as we go higher up the sail the effect lessens so we have to build in the shape.
The amount of draft to put in and where to put could occupy a discussion until the end of the world but like most things, there is a trade off. A large amount of camber (within limits) will produce more power (as in lift from and aircraft wing) but the drag will increase and the ability to point into the wind will be reduced. On the other hand a very flat sail would be able to point close to the wind but produce less drive. To complicate things, these conflicting features vary with wind strength. Foe example as the wind picks up you need to flatten the sail, however if the increased wind is producing awkward waves you may need to increase the camber and not point so high to get the power to push through the waves. Of course on a real boat all this can and is, adjusted in real time but in a model, unless you are using complicated radio equipment everything has to be pre-set. Most classes only allow 2 channels controlling the rudder and the winch.
We have to compromise and that will follow next.
Tim R
