It hasn't really taken me this long to make the keel. It's just I have not had so much time for posting.
A few more words here on sanding as there was a post a couple of weeks ago with some strong and opposed opinions. For shaping and painting I work from the rough side of a Permagrit which must be around 80 grit, then 180, 240 and finally 400. If the surface is going on to be polished this progresses to 800, 1200 and finally buffing with a compound.
It is a mistake to start off with two fine a paper when roughing out the shape. All that tends to happen is that you follow the existing contours besides which it is overly hard word and time consuming. The coarse grits are to remove stock and get the basic profile in shape. It doesn't matter if you have or get a few low spots, you can always come back and fill them. What you don't want is high spots. In the photo above, the strickled surface was sanded with the Permagrit to remove any lumps. It has had a second application of filler in the low spots and lines from the strickling.
This is the third and final filler application and only a small amount is required which is very quickly sanded smooth. The guides for the datum are carbon fibre and lamination lines in the wood which should be straight and the same on both side of the fine. At this stage I am still using 180 grit on a block.
The fin is now fitted to the hull and fully tightened into the correct position. The gap is intentional in order to make a close fitting join with the hull using some more epoxy and micro-balloons. The areas around the slot is carefully masked. It would make me very unhappy to glue the fin to the hull after all this work to make it portable!
Here the filler is squeezed into the gap making sure there are no air pockets and then rounded out with the end of a wooden coffee stirrer. The lumps at each end are purposeful as it is impossible to get the filler symmetrical while it is wet.
Yes it did come out after a sharp tap and the top of the fin not has a radius where it meets the hull just need to be trimmed and dressed to a nice shape.
A similar radius was made where the fin joins the bulb.
The fin has an aluminum core, carbon leading and trailing edges and wood packers. If the wood was ever to get wet through the smallest of cracks it would swell and cause all sort of problems so the fin was encapsulated with 25g /m2 glass cloth in epoxy. This also meant that I did not have to completely remove the scratch marks as all the finishing would be on top of the glass cloth which provides a uniform and stable base.
Finally in high build spray primer.
The keel on the right is from my Topiko IOM. The bulb weights are similar but the IOM has much more power due to the much increased draft and being all-carbon is very thin section.
Galileo is much beamier, has a shorter rig and I won't be sailing here in extreme conditions that the IOM has to put up with.
Tim R
