Well, Bob, I am after all a banjo player: when I see a string, I tighten it, don't I!?
And yes, a certain amount of work has gone into the dinghy, but then, why not? I mean, it will be displayed in a fairly prominent position on top of the hatch, so will be quite visible.
And speking of the dinghy, work has continued to progress, and last week it was finally time to start painting the hull, as usual with airbrush and Vallejo Premium RC Color paints. First up, of course, a coat of primer …
… both inside …
… and out.
As usual, the primer coat threw up a the few last beaty spots requiring filler and/or sanding, so after adding the final coats of gloss white paint to the inside, the outside received its final spots of Milliput.
Once this had cured, and the paint on the inside had been left for 72 hours to dry completely, it was time to start masking off the interior, first with a strip of 3 mm washi masking tape …
… followed by a gradual build up with increasing widths of regular Tamiya tape.
I had decided to paint the outside in dark gray, and after some experimentation with various paint mixes settled on 4 parts 62.020 black to 4 parts 62.001 white, 2 parts 62.014 dark green and 2 parts 62.018 sepia.
This was sprayed on in several coats which, once they were sufficiently dry for the masking tape to be removed, gave the following result …
I might still spray on some satin varnish on top of the dark grey, to dull it a tad more, but on the whole I am reasonably please with the result.
There still remains, of course, to make up the floor boards and thwarts, and also to add the various fittings and other details, but that'll be for later.
To be continued …
/Mattias
Edited By Banjoman on 13/04/2015 09:30:24
Edited By Banjoman on 13/04/2015 09:31:07
