Brutus
Brutus
Home Forums Scratch build Brutus
Viewing 25 posts - 126 through 150 (of 1,017 total)
  • #46067
    IAN_I
      @ian_i
      Hi Bob..
      Your non stop varying builds sure keep the interest going and Pauls latest venture is of some size.
      You will need all that room in the work shop.
      The work shop is also top gear, thanks for sharing.
        Out of the primeval soup emerge……… a modern Dinosauer!………….Brutus!………..(Fanfare of trumpets!….On a par with the Planet suite………Or the arrival of Phil Taylor at a darts tournament with a pair of Sheila`s!)
        Gerron with it!……….Don`t rush me!……..Moments like this, need to be savoured!
        OK Chaps….This is it……Whistle blown and "over the top" we go!…….lol
        Had great fun assembling the base layout (10 sheets)………Which is slightly too big for my base board!……Drat!
        Some of the formers and keel are on display
        For the princely sum of £1, you too could be part of the development of this fascinating build!…….Great fun and a refreshing change to revitalise your modelling taste buds and jaded palette!
        Paul…..Haven`t got the transom drawing?
        What thickness of skin shall we use?………..Might be worthwhile doing a broad strip plank on frame exercise?
        Bob the Builder
        #46084
          The transom (drawing 11) is on a single A4 sheet that was in the last set that I emailed to you.
          The skin is 1.5mm aircraft grade plywood or similar, an exercise in planking would be a good idea however the skin on Brutus has some tight curves that cant be achieved by planking but don't worry as we will do diagonal planking on the next build………can you guess what it will be?
            Next build?
            No idea……Give us a clue?
            Still not got the transom….Please resubmit
              Transom and horizontal panel drawings re-sent.
              A clue………..diagonal planking
              LARRY WHETTON
                @larrywhetton68737
                is it a………RAF RESCUE LAUNCH..?.. Larry…..
                #46094
                  Hi Larry
                  Better not be!……Can't stand 'em!
                  But it's got every chance
                    Larry
                    No its not an RAF launch, although as they are very popular I am intending to draw one up at some point.
                    Another clue…………….a single 800 size engine.
                      Now your talking!
                      Is it a big canal barge?
                      I need latest Transom info, please
                      LARRY WHETTON
                        @larrywhetton68737
                        OK ………..Is it a police patrol boat……….?…….
                        is there cash prize for correct answer
                        Larry………………………..
                        #46100
                          Hi Bob
                          No its not a barge and you have all of the Transom info (like I said this is a more difficult build)
                          Hi Larry
                          Sorry its not a police boat and the prize is one of Bobs awards.
                          Another clue…….think scarface.
                            You mentioned a "Sacrificial something or other " on the Transom, tell me more please
                            Any rudder info?
                            Tenon needed on keel end
                            'Think Scarface"……He said………Still no wiser!
                            Bob…..Fingers still tapping
                            #46130
                              Flippin` `eck!
                              What`s this?…..I said to my self
                              No wonder I couldn`t find the Transom……..This is it!
                              Looks like a bit of fun getting the skin to follow these curves?
                              It`s made up from three layers of 1/8" ply….For strength
                              LARRY WHETTON
                                @larrywhetton68737
                                Scarface ,… thats as to be Al Copone, ……………
                                so could be high power custom blockade runner …….?………..
                                Larry…
                                #46136
                                  Larry:
                                  You are getting warm as my next clue was going to be prohibition.
                                  Bob:
                                  Now you know why planking the hull wouldn't work very well.
                                  Rudder details are on my screen now so the drawings should be with you later today.
                                  LARRY WHETTON
                                    @larrywhetton68737
                                    A high speed power boat as used on the rum runner during prohibition
                                    A CRISS CRAFT …..may be or on that style of boat power v8 tuned motors …?…
                                    or the good guys US coast guard patrol boats ………
                                    violin case at the ready………cheers Loaded Larry……
                                    #46141
                                      Hi Larry
                                      You are now so hot as you are 99% of the way there.
                                      Ask yourself which style of boat owed its beginning to the rum runners and then have a think (perhaps have a look through my albums) Bob will get the answer now and I am certain that my old chum Dave M is shouting the answer at his computer.
                                      LARRY WHETTON
                                        @larrywhetton68737
                                        CRIS CRAFT ………?…………….
                                        RIVA AQUARAMA…….?………….
                                        laughyes 40 COATS Larry….
                                        #46153
                                          Now then….now then!
                                          We don`t want any further suggestions for the next boat, thank you
                                          It might be a stonking good idea and put me off Brutus!
                                          I can see an outrageous 21st Century Brutus, being a possibility?
                                          Anyway…….I`ve got enough to do as it is!
                                          LARRY WHETTON
                                            @larrywhetton68737
                                            Why Bob ,
                                            ITS a blinder , at least it looks like a boat ,…………..
                                            loads of brass work luv Larry…..
                                            #46159
                                              It the Barrel Back
                                              Bobs varnished version on Ellie has inspired me to revive this old favourite
                                                Hello Paul
                                                The Barrel Back is very close to the SloMo hull, I was not enthused by the proposal
                                                I could remove the SloMo top and make a Barrel Back top…..ish?
                                                Paul, you could knock up a BB top for Ellie and a mod to the hull, to get the droopy look? I fancy a long veneered top anyway?
                                                Had an idea…..Why don't you offer the current plans in the ModelBoats free advert section?
                                                Another string to your bow?
                                                  Hi Bob
                                                  Sorry but altering Ellie to make a barrel back wouldn't work as the geometry of the two hulls is completely different.
                                                  Placing an advert in the magazine might be a good idea, I am just wary of pushing my luck too far as the magazine owners, My Time Media, run a business part of which involves selling model boat plans.
                                                    You are probably right on both counts……It was just an idea
                                                    Got a cunning plan for building Brutus!……You`ll love it
                                                    Photos shortly
                                                      Ok Baldrick
                                                      'Lets hear the cunning plan' lol
