What material is used to make yacht Sails.
Home Forums Beginners What material is used to make yacht Sails.
  • #94479
    carl brotherton
      @carlbrotherton75833
      In a way the heading says it all.
      What materials are used for sails on a approx 1m yacht.
      The question then begs the question, what fittings are used on sails and where can you purchase everything.
      #3004
      carl brotherton
        #94480
          @timrowe83142
          Hello Carl
          Google Nylet for a mine of information about model yacht rigs.
          You will find loads of videos generally on the web if you hunt around.
          Tim R
          #94481
            Hi Carl,
            If you have a look at the 4th advert down on this forum view/page you will see Nylet, all will be revealed I have had 3 sets of sails from Frank Parsons and they are excellent.
            He also stocks all the rigging accessories you will need for your boat.
            carl brotherton
              I agree there are loads of videos and pictures on this site.
              I have and keep looking at them.
              Not knowing very much, the options that people have taken, are multiple for what passes for the same design, which I cannot put into any context, lacking both knowledge and experience. I am dependent on yo guys who have all the things I lack. I am grateful for any pointers.
              Ray I will look at the web site.
              #94487
                Carl
                Your hull shown in the main thread is looking pretty good now.
                I take it given the questions that you are asking on new threads that you didn't take the advice given to get the full set of plans from Sarik?
                I'm quite an experienced builder now but wouldn't contemplate building a yacht without a full set of plans! I know very little about sails and rigging etc. and would have to have all the details. There is much to go wrong otherwise and too many questions! As a beginner you really need to follow the designer's plans and instructions.
                The cost of the plans will easily be recouped and they should tell you everything you need to know and Nylet for example will probably have the sail design already in their library.
                carl brotherton
                  There are many reasons why I am satisfied with the drawing I have. There is probably a reason why i have not got the second sheet. Which would be to boring to relate.
                  In a way I am hesitant in my reply, in that much can be misunderstood and misinterpreted in my response, due to the limitations of the media postings and also my inherent limitations.
                  In the dim distant past, I was a one time engineer (Bsc (Hons) CEng Mi MechE). I produced drawings and had drawings made. The drawings would be given to tradesmen, also called engineers. These guys would have little idea as to what went through my or other designers minds, often having no idea of function, limitations or what was considered success. It was not unusual to receive a phone call, asking for a concession as what had been stipulated had not or could not be achieved. The tradesman undertook a different role than the designer, although often there skill was necessary to success.
                  In the case of the JIF, I lack the practical abilities to have built the model as designed. From my perspective the design appears to be the equivalent of a F! racing car, where I want a family runabout.
                  Many of the details on the drawing are beyond my abilities or access to materials and equipment to make them. There is a complication in that I have no idea as to how the bits and pieces are supposed to function. More importantly, I do not recognize what success looks and feels like, or what alternatives exist, and their benefit and limitations.
                  It may be seen as cheating, I know and want to tap into the knowledge and experience of those hundred of years of intuition and experience of those who do. In reality my whole life has revolved about standing on the shoulders of those who have been there and got the tee shirt.
                  I enjoy doing and understanding, otherwise why bother. Competition success is not my goal. Simply sailing a boat that can be encouraged to go where I would like. That is in a fuzzy sort of way.
                  Edited By carl brotherton on 29/03/2021 20:29:36
                  #94492
                  Kev.W
                    @kev-w
                    Carl, do you intend stepping your mast on the keel, or on the deck?
                    #94498
                      A word with one of the model boat sail makers, Nylet, HouseMartin, Sails etc, PJ, and no doubt others, will show that they already do suitable sails for your boat. They will cost rather more than DIY sails, but they will be better made and have a better chance of working as required.
                      Material? Take your pick. Poly cotton from a dead shirt, bin liners, shower curtains, florists cellophane, drafting film, rip stop nylon, all have been used successfully.
                      #94515
                      carl brotherton
                        Kev
                        The drawing calls for a deck stepped mast.
                        This is what i have intended producing. There is a deck plate which is the same diameter of the mast diameter stipulated. The drawing calls for CF mast. From my own experience pultrusion type CF tube has a tendency to split longitudinally, if a plug of some type is not taking the end load, distributing the stresses and strains into th end areas.
                        Again it is the lack of relevant experience that leaves me in a quandary.
                        Malcolm, thanks for the input, I am tempted to produce one set of sails as a starting point. This will allow me to involve my youngest daughter or possibly my youngest grandchild.
                        In many ways this model will benefit from a programmer of development as understanding, and possibly abilities improve.
