THE IDIOTS GUIDE
How to test the amp draw on your latest creation.
Firstly you will need one of these
A basic amp meter or multimeter
Set the meter to Amps (read the manual) and connect the meter between the battery and motor, as below
You don't need a speed controller or transmitter.
The motor must be fitted properly in the boat and connected to the propshaft and the propeller.
Place the boat in the bath so that it is floating freely with a couple of clear inches below the keel.
Carefully connect the battery as shown above………be aware that this setup is the equivalent of full speed, your model will move forward and produce a lot of prop wash (hence the need for a wetsuit)
The meter will show a reading which is this motors maximum amp draw in this particular hull (if the meter shows a negative reading simply switch the terminals on the battery) this is a good time to check the motor is turning the correct way.
The reading is called the 'On Load reading' and from this you can work out what ESC rating to use.
It is good practice to use an ESC rated at least twice the On Load reading for example a reading of 8A (8×2 =16A) so a 20A ESC is required.
That's it.
This test would be very revealing on experimental motor setups (like the Bobabell Drive) as depending upon how the motors are wired together…..either series or parallel…..different amp readings will be produced and these results might be far higher than the manufacturers data might lead you to believe.
Don't forget to fit in line fuses to protect against overload and motor 'stall'
No ESCs were hurt during these tests and no fingers were lost however the bathroom carpet was ruined
Edited By Paul T on 21/03/2015 19:23:54
