Taycol Meteor
Taycol Meteor
Home Forums All things floating Taycol Meteor
  • #125541
      The article by Charles Oates in the magazine brought back memories of having one when I was about 13 or 14. It was bought for my Veron Trident. I remember taking it to a paddling pool on the Embankment in Nottingham.
      I still have the Trident but the Meteor was sold a few years ago, when we were getting ready to move house.
      The Trident must now be 60+ years old, of course, now having a modern motor and RC.
      #125542
      Len Morris 2
        @lenmorris2
        Hi Tim, I still have my Meteor.  It was a birthday present when I was about 10 or 12 and went in mi first tin plate submarine.  There wasn’t much room in the soup can hull and that’s why the fibre side frame plates are chamfered at the top back corner.
        P1050796
        I remember it having more than enough power but it ate 6 U2 size dry cells and all mi pocket money in about 15 minutes!  As you say, thank goodness for the modern motors.
        Len. 🙂
        #125543
          You can’t beat these simple machines though for teaching kids how things work, which of course are just as relevant today as they have always been.
          Take this Stuart Turner dynamo for example, it is so staggeringly simple its hard to believe it works.  It is nothing more than a coil wrapped around a rotor with the ends being brought out to two slip rings with sprung brass arms running in a groove in the slip ring.  The magnetic field is simply a chunk of magnetised iron sat in the base.  So the rotating coil has a current induced in it by cutting the magnetic field as it rotates.  At the slip rings you get an AC current generated but, if you were to fit a commutator and a pair of brushes instead, you could create DC current.
          I connected it up to a small 2V LED and it produces a nice light to demonstrate the working.  Certainly not efficient by today’s standards but very satisfying anyway!
          11-03-15-09StuartPlantDynamoFinished1
          #125544
            That was a model article by Charles and I enjoyed it immensely.
            Well laid out and written, nice bright clear pictures, simple but effective hull nicely finished. Simple fix for the motor control issue! And more than adequate for the use it will get.
            Well done Charles.
            Charles Oates
              @charlesoates31738
              I’m really pleased that my little article has brought back some memories for people, and thank you for the very kind comments. The model was only meant as bit of fun and to get an old motor out of the cabinet and on to the water.
              If anyone has any ideas why the motor should interfere with several different types of speed controller but not with a servo I’d be really glad to hear them. As  I mentioned I hope to get the beefier Taycol standard in to a model sometime and I’d rather not end up with an old bobs board speed controller from my junk box
              Charles.
              Ps ive tried the Standard with a couple of esc s with the same result.
              #125550
                Charles
                You have started another memory of a Bobs Board in the Trident with a motor a friend gave me. I think it was out of a model car he used to race.
