Sound generators
Sound generators
Home Forums R/C & Accessories Sound generators
Viewing 25 posts - 1 through 25 (of 26 total)
  • #10038
    stoogie
      @stoogie
      hi guys. does anyone have a particular supplier of diesel ‘sound generators’ they could recommend. preferably a supplier with a website. thanks
      Archibald Mainstream
        @archibaldmainstream22940
        try http://www.actionkit.co.uk
        An excellent range highly recomended.
        #10045
        stoogie
          @stoogie
          thanks daryl. will try that
          #10066
          DickyD
            @dickyd
            Try JJC Sound systems from Westbournes.http://www.westbourne-models.com/erol.html#2583X0
            Excellent
            #10119
            Armando Loni
              @armandoloni78860
              See also Hunter Systems website.
              #10164
              Phillip Pittwood
                @phillippittwood85612
                I have looked at your Emails with interest,as I have been trying to get a sound board for several weeks now from Hunter Systems but all are out of stock and there does,nt seem to be any rush to restock
                #10166
                Paul Freshney
                  @paulfreshney24971
                  JCC and Action both offer a range of noise generators as do others. Action is under new ownership following the sad death of Craig Talbot who founded the business. Action are available direct only (they have a good straightforward website), or JCC are via model shops such as Westbourne Models or direct at model shows/exhibitions. What is important is that you have the most effective loudspeaker you can install. What can be a really loud noise in the workshop, turns into a whisper once the model is on the water and 10 feet from the bank! The magnetic field generated by the loudpeaker can also interfere with the rx aerial. Therefore I would suggest keeping the two as far apart as possible. My Waveney Lifeboat, ‘The Scout’ has a ‘turbocat’ JCC noise generator installed and effective it is too. Be careful with wiring the thing up though. one wire wrong and it won’t work and you could damge the electronics.
                  #10964
                  Geoffrey Ashworth
                    @geoffreyashworth37297
                    I am hoping that JJC will be at the Boat Show this month. have emailed, telephoned (answering machine & no reply) and sent 2 letters – ditto reply
                    #10981
                    Terry Small
                      @terrysmall72176
                      Rumour has it and if its true what a loss that JJC is not going to continue with selling these super sound systems. Thier web site is still active but no phone answer or email replies. If they are to stop then I wish JJC would tell us all. He builds up the business sells the products then walks away.
                      #12216
                      Model Solutions
                        @modelsolutions
                        Guys, try Model Solutions of Canada Ltd.
                        They make premium sound modules that can store up to 10 digital recordings (not simulations!!) and has a USB interface so you can download your own sounds to it.
                        Their flagship model, the SFX4-4 also has a built in 16 channel switch decoder and has up to 8 switched auxilliary outputs in addition to the sounds.  These units use a highly effiicient output stage that pumps out 12Watts into 8 ohms at 14V with NO HEATSINK, and NO FAN.
                        At the upper end of the price range they are still much cheaper than the Robbe sound system which is just over £100 and has only 6 sounds, 2 switched outputs and is still NOT DOWNLOADABLE.
                        Considering a 16 channel switch switch decoder will set you back £75 alone, with no sounds, the SFX4-4, at £85 is actually a very good bargain!!
                        #12217
                        DickyD
                          @dickyd
                          Why not tell everyone that you are Model Solutions of Canada Ltd. David ?
                          Honesty is the best policy you know.
                          #12218
                          Vinnie Branigan
                            @vinniebranigan92297
                            I was thinking that myself.
                            Vinnie
                            #12221
                            DickyD
                              @dickyd
                              I personally would hold fire on buying a sound generator at the moment as since the demise of JJC a number of companies are working on making an affordable one. ACTion Electronics being one company.
                              #12222
                              Model Solutions
                                @modelsolutions
                                O.K. Point well taken, Yes, of course I am Model Solutions.  I couldn’t find any policy statements about commercial postings on this forum, so I didn’t want to get torn to shreds over it.
                                Now that I’ve been torn to shreds anyway, let’s end that nonsense.
                                As regards affordability, first be sure you compare apples with apples, not oranges. There simply is nothing else out there to compare with ours. They are simply head and shoulders above all other competing sound units in terms of their functionality.
                                Remember, you get what you pay for!!
                                Also we are working hard on our next generation sound units which will be a lot smaller, simpler, smarter and much cheaper – starting around £30. Availability May-June 2008.
                                #12225
                                Geoffrey Ashworth
                                  Many thanks folks – all useful to me
                                  #12226
                                  HS93
                                    @hs9317166
                                    I would sugest, befor buying ANY sound unit have a listen to it first, as a lot are just noise genarators and  dont sound anything like the real thing. if the sellers don’t  put a sample of there sound on there web site , is there a reason ? jjc always did and they sounded like the real thing but sadley they dont trade anymore, some people have  different ideas what a good sound is.
                                    peter
                                    #12227
                                    Geoffrey Ashworth
                                      Hi Peter
                                      thanks for your reply – I agree that the JJC sound certainly sounded realistic.
                                      does anyone know is anyone is doing anything like the JJC ‘Old Smokey’ i.e. working of water only and 6 volts? A friend of mine can’t use the normal ones because he has a chest problem.
                                      Geoffrey Ashworth
                                      #12229
                                      Model Solutions
                                        @modelsolutions
                                        Just In case you’re wondering, we don’t post sound samples on our web site because there are so many of them, and we don’t want competitors stealing them, but if anyone wants samples prior to a purchase, we will gladly send them.
                                        We have nothing to hide, all our sounds are actual digital recordings. our units are essentially digital playback units, not simulators or "noise generators".
                                        We are in the process of sourcing additional engine and weapons sounds.
                                        #12316
                                        alan summers
                                          @alansummers16434
                                          great one on ebay at the moment
                                          #12527
                                          Barry Addis
                                            @barryaddis83049
                                            David. Why do you not have a UK distributor ? (or as a new guy to marine modeling maybe you do and I dont Know )more so now that JJC seem to have ceased production. I hate ordering from abroad but like many are always looking for new good quality products.
                                            Barry Addis
                                            #12530
                                            Model Solutions
                                              @modelsolutions
                                              Barry, and any other UK folks out there.  We are working towards a U.K. distributor for our next generation SFX5 sound modules. It will be ACTion Electronics. I am sure many of you know Dave Milbourn from ACTion.
                                              There really are few problems buying from us in Canada. I realise the shipping may be a little more and you may have to pay a little in customs duty.  But if you are willing to wait about two weeks for delivery, we can get a sound module (no speaker) to you for as little as $15-20 shipping charge.
                                              We have shipped, and continue to ship, all over the world including Tokyo and Australia.  Many hobbyists seem prepared to go to any supplier in any country to get what they need to make their models truly extraordinary.
                                              BTW, we have reached an agreement with our Canadian Armed Forces Imagery Centre to get access to hundreds of original military recordings  of Canadian Naval vessels, inside and out and many recordings with our forces on the ground. This is a source of unique and genuinely original military sounds that we, alone, will have access to.
                                              More news coming later when we have the sounds in our possession.
                                              #12721
                                              Model Solutions
                                                @modelsolutions
                                                Thought I’d let you know that we will be publishing a quarterly newsletter, starting end of this month. It will bring news and updates about existing products, new product announcements and new products in development.
                                                If you would like to subscribe, send an email to [email protected] with "newsletter – subscribe" as the subject line.
                                                You can unsubscribe at any time by sending an email to [email protected] with the subject line
                                                "newsletter – unsubscribe".
                                                #13462
                                                Andy Hustler
                                                  @andyhustler32076
                                                  All this info is making my tiny brain spin down here,what i want  is a sound generator that wil sond like a fog horn and the "whoop whoop" sound that ships make also is it possible to get a sound generator that will sound like 4.5" guns.
                                                  #13467
                                                  Model Solutions
                                                    @modelsolutions
                                                    Andy, we have several fog horn sounds to choose from as well as the warship whooper. We have a 4" gun sound and various other naval weapon sound.
                                                    Please see our sound catalogue at : http://www.modelsolutions.ca/soundclips.htm
                                                    #13676
                                                    Terry Small 2
                                                      @terrysmall2
                                                      Any modeller who wants sound in there boat or for that matter any model will be proud of this product . JJC left a big hole when they stopped trading now Model Solutions has filled the hole and made it overflow with the SFX4 module and soon to come the next generation SFX5 range of easy fit modules contact them or Action Electronics.
