Rudder assembly
Rudder assembly
Home › Forums › All things floating › Rudder assembly
  • #99561
    Andrew Cadden 1
      @andrewcadden1
      I have finally thanks to your advice and my friend here in Aus worked out how to connect twin rudders so that they operate as they should with good turn to port and starboard. To do this all I had to do was make a longer servo arm which created the correct arch so that I got max turn in either direction, see image attached.
      I also note another issue when full stick to go forward it behaves as if its in reverse and full stick in reverse it is behaving like it should in forward motion very fast, should I reverse the propellers as well as change the polarity of the motors to correct the above, thanks in advance to your advice.
      #4789
      Andrew Cadden 1
        @andrewcadden1
        Yorkshireman
        #99562
          Hi Andrew. Simply reverse the motor connections to get the props to turn the right way.
          For brushed motors simply swap the leads over, for brushless, swap any two wires about.
            ….or simply reverse the channel on your radio set. The manual will show you how to do this if you are not sure but it's usually only a button or two.
