Finally managed to get all the first layer of planking on the hull ( all108 each side )and have put some pictures on the album, warts and all!
I have to say, some of it went on very well and some of it was, frankly, horrible! At the moment it`s had a bit of a rub down to highlight all the pitfalls , and there are many, so it all looks pretty rough. The pencil lines are showing where the rubbing strips went so that should eventually hide the change in angle. The lines on the hull at the stern are to show where the prop shafts will come through. I do like the shape of the hull with it`s many changes of angles as you go from bow to stern and this is where my next problem is coming from.
My original plan was to double plank ( and that still might happen ) but where I am at present shows the hull to be sturdy, and apart from the thinning of places with the rubbing down, would almost be enough. There are quite a few peaks and troughs over the length that will need filling to smooth the shape out and I`m wondering if when doing that I could use filler on the whole hull. If I second plank I will change the angle to something more suited to the shape, especially near the stern where the curves are tight. At least there will be a good gluing surface to work with.
Jim.
