Hi Noel,
I’m a newcomer too, but seeing as no one else has replied yet I’ll chip in with my 2p, as I’m building the 1/32 all wood Perkasa. I received some advice from people at various model stores and traders at shows.
Firstly, you can get better performance going with a brushless/lipo setup, but it’s expensive, so I went a more conventional route using 2 x 545 brushed motors and 2 X 9.6V 3700 NiMH battery packs. I’ve got 35mm screws on my shafts, and a 40amp Mtroniks Viper speed controller. The speed controller is way overkill, but I got it at a really good price, and I thought I could always use it for a future project if I needed it, and then replace it with something more suitable.
The 545’s are cheap, and the battery packs aren’t too bad either.
Of course my boat is not finished yet,
so I can’t say for sure how it will perform, but in testing it sure sounds good!
I think if you went with 3 545s and 3 battery packs you’d probably be ok. You could probably use two motors if going for more performance oriented motors (Graupner have several models) or going brushless – but it will cost you more.
Let me know if you have any questions, and maybe someone more experienced can point out any errors or problems!
Hans
Edited By Hans Kuhn on 22/03/2011 18:11:10
