need a small water pump for a 32cm model and monitors to squirt water from
Home › Forums › R/C & Accessories › need a small water pump for a 32cm model and monitors to squirt water from
  • #5050
    boat building disastor
      @boatbuildingdisastor
      #22500
        help i need a micro water pump and some watermonitors for my model it is only 32cm long so space is a premium please
        #22504
          Make sure you’re sitting down when you look at the price list.
          I think you may have to make your own monitors, but at that scale it shouldn’t be too difficult to tart up a length of brass tube with a handle and a tapered nozzle and solder it on top of another length of tube as a pedestal. The hose should be as flexible as you can find; would suggest surgical silicon tube, thin-walled.
          Good luck!
            many thanks is this somthing you might be able to help me with
            #22508
              #22509
                Check out fleabay item no 320313193816 for a mini pump at £6.99
                  can you send me a link to the page cant sem to find it
                  #22537
                    James Ramsey
                      @jamesramsey10541
                      that mini pump works on A C according to sales blurb!!!!
                      #22997
                        #23009
                        David Meier
                          @davidmeier28154
                          What about the electric windscreen washer pump from a car wreckers? It would be 12V dc.
                          David.
                          #23019
                            Posted by David Meier on 06/09/2009 09:37:10:
                            David.
                             A bit large for a model barely a foot long, methinks, and a 12v power supply would be even larger.
                            #23021
                            David Meier
                              @davidmeier28154
                               Dave wrote, “A bit large for a model barely a foot long, methinks, and a 12v power supply would be even larger.”
                              Fair enough.
                              David.
                              #23066
                                Try using the pump bits out of a kiddies water pistol connected to a small motor.
                                A bit Heath Robinson but it does work.
