Matt finish for decks
Home Forums Sailing Models Matt finish for decks
  • #70802
    Martin Field 1
      @martinfield1
      Since the decks on "Vanity" are meant to represent scrubbed teak, I will need a matt finish. Can anyone recommend a waterproof matt varnish/lacquer that will set reliably flat, please.
      Cheers,
      Martin
      Martin Field 1
        @martinfield1
        #70803
          Try Ronseal Polyurethane Mattcoat. (The solvent version – don't use the quick dry type). Rustins and Blackfriar do similar matt varnishes. You will probably need to go to an old style ironmongers to find it in small tins as the big DiY stores now mainly only sell the acrylic quick dry type.
          There will be a very slight tint as with almost all solvent based varnishes. The interior version is best and will be perfectly OK for a model. The exterior version contains anti UV filters and is slightly yellower.
          Edited By Colin Bishop, Website Editor on 29/04/2017 17:52:24
          #70804
          Martin Field 1
            @martinfield1
            Splendid. Many thanks, Colin. I take it by solvent version, you mean effectively oil based, with that distinctive smell. Longish drying time.
            A slight tint isn't a problem as scrubbed teak can change it's colour dependent on the weather and how often it's been scrubbed!
            Cheers,
            Martin
            #70805
              That's it, the smelly long drying stuff!
              Be sure to stir it well to get the full matt effect.
              Martin Field 1
                @martinfield1
                Lovely stuff, Colin. I wish I wanted the gloss stuff because I already have some of that. I bought it as fuel proofer for a model aircraft. But these decks must be matt. I shall get some.
                Thanks again.
                Martin
                Edited By Martin Field 1 on 29/04/2017 20:27:51
