HMS Belfast
HMS Belfast
Home › Forums › R/C & Accessories › HMS Belfast
  • #73032
    Max Cormick
      @maxcormick
      hi guys,
      I bought Graupner HMS Belfast
      I have to buy ESC ; they say Graupner Navy 40R….
      can you help I found Navy 30R
      is suitable or I must buy Navy 40R?
      regards
      Cobby
      #5490
      Max Cormick
        @maxcormick
        #73035
        Max Cormick
          @maxcormick
          anyway can you help me : I would like to use esc ( used for motors) also as we have motor-assist in harbour maneuvers
          #73039
          Dodgy Geezer 1
            @dodgygeezer1
            Graupner will recommend their own equipment, but other equipment should do just as well.
            This site specialises in ship radio control electronics, and can certainly provide any control system you might want. **LINK**
            Contact them on +44 (0)1248 719353 and explain what you are looking for. They are very friendly!
            #73281
            Max Cormick
              @maxcormick
              question :
              is it possible to use 2 ESC ( with bec) and a single battery pack?
              #73283
              Dodgy Geezer 1
                @dodgygeezer1
                Yes, quite easily. You would only use the BEC from one ESC, and disable the other by taking out the +ve (red) wire from the receiver plug. Contact the link I gave you above – they will explain it all…
                #73284
                Max Cormick
                  @maxcormick
                  thank you I saw:
                  http://www.action-electronics.co.uk/pdfs/Disabling%20BEC%20ESCs.pdf
                  and I will do
                  All my best
                  Maurizio
                  #73385
                  Empire Parkstone
                    @empireparkstone
                    Before you use up cash on what you may not really need find out if you can get spare props as you will break them sooner or later they are probably still plastic as the other graupner models .If you can't you are looking at custom modified ones being made as they are not threaded. also she runs fast enough on 2 props
                    Ep
                    #73386
                    Max Cormick
                      @maxcormick
                      you right….propshafts are not threated I would like to use Raboesch propellers …not sure on which type….
                      I have this ship Still in the box but next week I will have enough time to measure propshaft lenght and if it is easy to change them with a threated propshaft 3M I suppose
                      second step will be to use first the original propellers with 2 esc to see how it will move on the water and improve her turns
                      cobby
                      #73387
                      Empire Parkstone
                        @empireparkstone
                        Yes once you have threaded shafts you are spoilt for choice on props the one on our lake is far too fast even on two motors to be honest its a bit on the small side he still has not got it ballasted right
