Hi ,new member would like some help identifying old battery boat
Home Forums Collectors’ corner Hi ,new member would like some help identifying old battery boat
  • #29129
    soulpatrol
      @soulpatrol
      Hi everyone
      i recently purchased this boat and would love some details on it.
      for the agee its very well made with aluminium hull and topdeck which is covered in small planks ,very well detailed
      twin taycol engines and a weird auto steer type thing !
      its 40 inch long
      all details would be most grateful
      “>” width=”350″ alt=”” />
      Edited By soulpatrol on 10/12/2010 10:43:39
      soulpatrol
        @soulpatrol
        #29189
        soulpatrol
          @soulpatrol
          Hi everyone
          im sorry if i have offended anyone ,is this the wrong catagorie or has nobody got anything to say about the boat ?
          #29190
          The Long Build
            @thelongbuild
            No, I don’t think you have offended anyone, probably you have stumped everybody , also when you try to enlarge the pictures I get error messages that the picture is not avaialable.
            You will get an answer at some stage.
            Why not double your chances for information and try The Model Boat Mayhem Site.
            #29191
              I also seem to be unable to open the pictures so perhaps they need re-posting
              #29198
              soulpatrol
                @soulpatrol
                thanks for your reply’s heres the pics again , i have had to add them as large pictures it seem s the only way it will work.
                all comments on the boat very welcome
                Edited By soulpatrol on 16/12/2010 09:35:37
                #29206
                  Wow. Thats all I can say. Some task there for restoration!  looks like contacts to power the lift off top at the front there…the rest  ??  It would be a real treat to see it running as intended with all that…stuff..working correctly. I should think you would spend hours figuring out the electrics before even attempting any thing else.
                  I would advise a special aluminium primer coat before repainting, if thats what you intend to do.
                  It must be a commercial boat with an ally hull and superstructure? are there no makers marks or tiny transfers anywhere?
                  The Long Build
                    @thelongbuild
                    I can see that looking a very nice model when restored.
                    #29217
                    John Walsh
                      @johnwalsh23400
                      This has a vague similarity to an old Vic Smeed design called ‘Lorraine’.  though the plans were for a 54” length x 12”beam hull. it could have been re-scaled.  It was described as having ‘an ingenious construction giving a choice of methods and either a hard chine or rounded hull.’  I have a copy of the 1998 Model Boats Plans Service catalogue which gives the plan number as MM 512.
                      I may be totally wrong of couse…. John w
                      #29231
                        It does have the look of a Vic Smeed design but I disagree with Ashley about it being a commercial product as the lines of the hull are irregular and if you take the C/L along the keel the R/H & L/H are not mirror images.
                        Nice model though and it will look a stunner when restored.
                          There was a question mark in there.
                          But its a lot of work for a home made job, unless they were a panel beater or a tinsmith etc
                          My brother had a gas speedboat a while ago and he needed a fuel tank, you know, shaped to fit around all the bits and bobs, and he was working at Hawker Siddely in Kingston at the time (just shows how long ago it was).
                          We did a sketch and he gave this to an aircraft grade sheet matal man in the workshop, and he made an absolutely spiffing tank, beautiful, a work of art AND pressure tested to boot, welded in Harrier grade alloy naturally. Took him a couple of lunchtimes.
                          When you know what to do of course these things are easy
