Sketch showing idea for furling genoa stay. The plan is to use a 5mm alu' tube inside a 6mm alu tube. This should be stiff-ish and is light in weight. The 6mm tube has inside dia. 5.1mm !!
Have not managed to push the 5mm tube into the 6mm tube yet but working at it with WD40, stern-tube lube and 1200 grit wet&dry! There seems to be a good bit of alu' dust and gunge inside these tubes from the production process.
I'll may try warming up the 6mm and coolingdown the 5mm when I have ascertained the respective lengths of the tubes. The 5mm will be cut about 15mm shorter than the 6mm outer to make sockets to house the swivels/bearings. They'll also be a deck-level bottle screw which is not on the sketch.
Any comments or suggestions on this are welcome, as usual I'm only guessing at the construction method ! Keep in mind though that I have very limited workshop facilities. Admiralty suggests that other facilities/faculties are not much to shout about either.
George
Edited By gecon on 21/01/2021 15:50:31
Edited By gecon on 21/01/2021 15:51:20
