Billing Boats Bluenose 576 1:65
Home › Forums › Building Kits › Billing Boats Bluenose 576 1:65
  • #6334
    Norah Johnson
      @norahjohnson75438
      Piece 48? or lack thereof
      #94067
      Norah Johnson
        @norahjohnson75438
        Hi! I am fairly new to model boats, i have only done ones at this level that had extremely detailed instructions. And on this kit, there are virtually no detailed instructions. So, to anyone who has done or is currently doing the bluenose #576 from billing boats, where could I find piece number 47?
        Many thanks from a boat newbie.
        #94271
        gecon
          @gecon
          Hi, doesn't seem like there are many 'blue-nosers' heresad to help you.
          Your title refers to part 48 and the text refers to part 47.
          In both cases it looks like they have to be CUT from the appropriate size of wood which should be included in the kit. The wood might -of course- not even be in the box and then you deffinately won't find itno.
          Good luck!
          George
          #94273
            There is a build log on this forum. It does seem that the models is a rather frustrating build! As George says, you probably have to cut these pieces from wood of the described dimensions provided in the kit.
            Edited By Colin Bishop on 16/03/2021 11:08:31
            #94274
            Trevor Drabble 1
              @trevordrabble1
              Norah , Have you tried contacting Billing Boats directly ? Trevor.
              #94278
              gecon
                @gecon
                I don't think they have instructions either….don't seem to want to supply them with their kits.smiley
                A bit like Ashley…all is to be kept hush-hush.secret
                Had another look ….deffinately looks like the parts are to be cut from Obechi strip supplied in the kit…somewhere.
                George
                Edited By gecon on 16/03/2021 13:45:05
                Edited By gecon on 16/03/2021 13:47:07
