Battery charger
Battery charger
Home Forums R/C & Accessories Battery charger
  • #23149
    Ian Gardner
      @iangardner62867
      Hi everyone,
      I have decided to try and replace my motley selection of chargers with one all-singing all -dancing model if possible. I need a a charger that will charge any number of cells, say from four to ten at currents from a trickle charge up to 5amps. It would be nice to charge 6v and 12v SLA batteries as well. I gather it’s good to completely discharge occasionally too so that would be good. It would need to have Delta Peak sensing shut-off as well.
      I have a book called the Complete Marine Radio Control Manual and the author mentioned the Mainlink Digiliser 2000 but the book is ten years old now so that may not be a current model- I can’t find a supplier on the web.
      Has anybody had experience of a charger that would do the trick. My grasp of electrical matters is tenuous to say the least so simple operation would be a bonus.
      Thanks in advance for ant help offered.
      Ian Gardner
      #5053
      Ian Gardner
        @iangardner62867
        I need a charger to charge a variety of numbers of cells.
        #23150
        60watt
          @60watt
          While SLA manufacturers say capacity increases after SLA batteries are used,I don’t think they recommend discharge/charging.
          #23151
          Ian Gardner
            @iangardner62867
            Hi,
            I wasn’t thinking about a discharge facility for SLA’s- only Nicads and NiMH batteries- maybe my post wasn’t as clear as it should have been. I have discovered since my first post that Mainlink supply the Digiliser 2000 so I need to do more research on that one.
            #23154
            Paul Freshney
              @paulfreshney24971
              Hi
              http://www.logicrc.com have a big range of chargers as do Graupner. I have a Mainlink Digiliser 2000 which has given excellent trouble free service for both my NiMh and NiCd’s, BUT it is relatively slow charging and discharging, but that is not a problem for me. It isn’t particularly cheap but is robustly made.
              Paul Freshney
              Editor of MB.
              #23160
              Ian Gardner
                @iangardner62867
                Thanks again Paul for solid and helpful advice. I’ve had a look at Logicrc and some of the Graupner items. I think the Mainlink one does more than I need really and so just have to choose the right one from the rest. Thanks again for your suggestions.
                Ian Gardner.
                #23768
                Aridlands
                  @aridlands
                  Hi, I recently bought the E6 charger from Britflight for a good price. Charges NiCad, NiMH, SLA and has a discharge and cycle facility. Charges at up to 5A.
                  #23769
                  Ian Gardner
                    @iangardner62867
                    Thanks for your reply.
                    I too bought a charger in the end and it does everything I need it to and more. I think there are quite a few on the market that charge all types in any quantity  and discharge and cycle. Mine is a Sigma II EQ. It wasn’t particularly cheap but it was what my local model shop had on offer ( not when I made my original post) and I like to try and support him where I can. I’ve seen shops come and go over the years and it must be even more difficult for small traders in the internet age.
                    Thanks again for the suggestion.
                    All the best,
