Waterproofing a sea commander
Home Forums Beginners Waterproofing a sea commander
  • #84892
    Andy hop
      @andyhop65854
      Hi
      Im just building my first R/c Boat being the sea commander , newbie
      Question what can i use to waterproof the boat ? Im at the stage now
      Before any of it get closed up ….
      Thanku
      Andy hop
        @andyhop65854
        What is used to waterproof wooden R/c boat pls
        #84893
          Hi Andy,
          A couple of coats good quality varnish is fine for a plywood boat, if you not concerned about cost West epoxy resin is the best stuff. 😀
          Andy hop
            @andyhop65854
            Hi Ray Wood 2
            If i use either varnish or the west epoxy can these be painted over ?
            Or use varnish inside boat and epoxy on hull ?
            Thanks
            #84899
              Hi Andy,
              West is good inside & out and can be painted,
              And externally on the hull sanding sealer then paint, you may read about glass cloth & resin, but not really needed on your Sea Commander, I've built a few 😀
                Andy hop
                  @andyhop65854
                  Afternoon
                  Thanks for the info ive gone with west epoxy as I have now another 5 kits ordered
