Having tried it in the past with less than satisfactory results I am about to install the water cooling intake pipes on my latest model ( a twin screw crash tender)and seek some advice on the following:-
1/ What diameter of pipe is it best to use for the intake?
2/ How far back from the prop disk is it best to locate the intake end of the pipe?
3/ At what height with respect to the disk of the prop and on the rising or falling curve of the blade?
4/ What diameter of silicon tubing is it best to use to connect to the cooling coil round the motor?
(I would appreciate informatiom from those who have actually successfully installed this feature please).
Rick.
