I have now finished planking the deck, it just needs a couple of coats of sanding sealer.
Having read conflicting advice on what controls are needed to sail a TSB I have gone for full control of everything
With all the outlets for the sheets in place I can then choose which ones to use. Under the side decks there are two more tubes, one each side to allow me to lift and lower the lea boards, I feel that being such a prominent part of a TSB they should be working, I know they will only add drag and slow the boat down but I an not into racing, not yet any way.
The centre outlet is for the mainsail, the two at the front at the sides are for the vangs, but only one will be used now, after talking to Ray at Headcorn, the two behind are for the lea boards, there is also a loop of tube going around under the rear deck to take the winch line for the main sail control.
The two outlets for sheets are for the foresail, the first one, and the second is for the main sail, as someone wrote that it is better to control that sail from this position, I will see, it's there if needed!
Finally the hull has had a coat of epoxy resin and glass and is ready for paint.
Eddie.
