Thames Sailing Barge Stuff
Viewing 25 posts - 476 through 500 (of 782 total)
  • #88775
      Hi All & Dave,
      I really never thought about about this build blog as being instructional !! But I guess it is 😄 so here goes, top tip for working on your hull which is quite big and holding it at a good angle for working upon isn't always easy. Use a length of rod or piano wire with a brass collet to make an adjustable stop to hold the hull at a good angle for working on .
      This works well as we have a tube bonded into the hull for the keel retaining studding 😎,
      Coffee stirring sticks make an ideal capping to the bulkwarks of vertical grain liteply. Regards Rayimg_20200606_163551.jpg.
      Dave Sansom
        @davesansom26019
        Coffee stiring stick
        Thanks for that
        Eddie Lancaster
          @eddielancaster
          Not having been out for a coffee since mid March my stock of stirring sticks is running low sad.
          Eddie.
          #88779
            Hi Eddie,
            Yes I'm down to my last 500 !! Waitrose have stopped the free coffee 😕
            I'm hoping to get on the water soon 4 boats to test 😄
            Are you heading home anytime soon ? Or are you fully settled in Kent 😉
            Eddie Lancaster
              @eddielancaster
              Hi.Ray, I was talking to my daughter this morning and she says I should stay here unti the end of June at least, so I am having to think of my next build, maybe another DM kit.
              Regards and good sailing, will that be local or Bluewater?
              Eddie.
              #88938
                Hi Eddie,
                We should have been in Spain now 😢
                I'm thinking of taking a fleet of new boats to the Military canal at Hythe for testing as Bluewater is shut & Cygnets img_20200610_212441.jpghave issues with works on the Mote Park lake.
                Still pressing on with Portlight's leeboards she is steel I'm trying to give the impression of fabricated riveted construction actually 1/8" birch ply with 1 /32" ply overlays, getting a bit carried away 😄
                Regards (furloughed) Ray
                Edited By Ray Wood 2 on 10/06/2020 21:47:48
                #88946
                Eddie Lancaster
                  @eddielancaster
                  Hi. Ray, it’s the seemingly little things, like rivets, that make e model look finished and lift it from just being a model to a scale miniature.
                  Regards and keep up the good work.
                  Eddie.
                  #88950
                    Careful Eddie, don’t start counting rivets…
                      @timrowe83142
                      I Like what we call Cartoon Scale in model aircraft. The occasional rivet is great and it looks the part from social distancing!
                      Mind you Ray does seem to have time on his hands.
                      Tim R
                      #88965
                        Thanks Tim,
                        Token gesture to scale effect 😄
                        Never thought I'd be looking forward to going back to work !!!!!!!
                        Started the YM Eventide drawing today looking forward to the build 😎
                          Trial fitting of the Lee Boards, now i must get on with the rudder
                          #88986
                            Hi Ray
                            How come that the Lee Boards are not used on model races?
                            They would behave as a sort of keel and stop the side slip?
                              Hi Bob
                              Yes they would help against side slip, but insufficient righting moment for anything less than very light conditions, we do have an AMBO member who does it properly with independently controlled steel Lee Boards, but the barge won't point very well into the wind. goes really well running down wind
                              The first post on this thread shows the keels we use around 6 – 7 lbs
                                img_20200613_093318.jpgHi All,
                                Slightly off topic, but as it's the weekend I needed a change from model boat building all week, so as Ikea aren't making flat pack barges yet 😄
                                Decided my large tug Cullamix needs a decent barge to tow, as it seems pointless having a tug on it's own, here is the 80' Swim Head Barge @ 1/24th scale = 40" long by 11" beam. it should look the part mainly 5mm ply 😎
                                #89043
                                Eddie Lancaster
                                  @eddielancaster
                                  That looks good Ray, you will definitely need two of themlaugh.
                                  Regards.
                                  Eddie.
                                  #89061
                                    Hi Eddie,
                                    One will be enough for me 😄
                                    Forward swim deck & Samson posts installed through to the base for strength from mahogany for towing, good day on the beach with the grandchildren in our bubble 😄😄😄
                                    #89074
                                    Eddie Lancaster
                                      @eddielancaster
                                      Is that a portable bubble then? Will you b e fitting a fixed rudder to stop the back from swinging about?
                                      Eddie
                                      #89076
                                        Hi Eddie,
                                        Yes we paid extra for the portable one 😄 the beach is the best place for social distancing.
                                        The stern swim has a big skeg with external bracing 👍
                                          img_20200615_191140.jpgHi All,
                                          Latest progress, the rear fixed skeg with some brass strip bracing as per the full-size practice, and a few details for the foredeck, may get her finished tomorrow 😄 for a break from modelling I have bought a fishing rod, seems a good excuse to sit by the river for hours on end 👍👍👍,
                                          #89080
                                            Blimey, Ray…..That hasn`t taken you long to build?
                                            Are you going to fill it with coal?
                                              Hi Bob,
                                              I'm going to call the barge" Four Days "
                                              Yes I have 1/2 cwt of Welsh steam coal in the shed, it will be great for ballast 👍
                                              I still have my grandfather's loco he built in 1946, it's On its second boiler 😄
                                                What Loco is that, Ray?
                                                One of LBSC`S I hope?
                                                Or Henry Greenley?
                                                  Hi Bob,
                                                  It's a version of a South African narrow gauge loco the size of a 5" gauge but on 3 1 /2" gauge , 0 -6-0 tender engine, she comes out for the kids now occasionally 😄I
                                                  I am a massive fan of Curly's style of writing 👍
                                                    Ray has just amply demonstrated the speed at which boxy things can be build in plywood..like, for instance, a small Titanic, or a barge even. It is a constant source of amazement to me that people are surprised at how quickly one can build stuff like this (not just you, Bob).
                                                    Looks good Ray, and one would be surprised if it DIDNT look good considering. It will be a work of art once splashed with (Matt black?) paint and fully laden with scale coal. Are you going to have the ballast, whatever it is, in a removable ….tub..or whatever Ray?
                                                    we made Noel build his barge large enough to fit the tug inside, to save on storage and I think I said it at the time, it does look much tooo big out of the water but once in and hitched up it looks spot on.
                                                      Great morning walk today along Iron Wharf boatyard at Faversham while taking pictures of Ironsides a steel tsb, the owner Toby asked my wife an I if we would like to come aboard ! We jumped at the chance for the full tour below decks as she is their liveaboard home. Very inspiring morning 😄 now where did I put Portlight !!
