Gary
The following should fully explain what Flash Steam engines are and how they work, sorry that is so long winded but it is very accurate.
The phenomenon of ‘flash-steam‘ is well known to engineers and its application to the steam engine offers a route to significant improvements in steam generating efficiency.
Water if pressurized remains in the liquid phase at higher temperatures and does not boil and vaporize. If such pressurized and heated water is released through an orifice to a lower pressure, part of the water immediately and explosively turns to steam – a process known as ‘flashing’. Flash steam is currently exploited in applications such as geothermal power plants. In these, water is drawn from deep underground where it is at high temperature and pressure. Piped to the surface, this water is ‘flashed’ in a chamber to produce steam under pressure which is then expanded in a more or less conventional turbine coupled to an alternator to produce electricity.
Flash steam, therefore, offers one novel way of making a modern steam engine. In Section – 3 the mono-tube steam generator was described. This was the type of steam generator favored in the last production steam cars and was often found in stationary or ship steam plants. This type is almost always employed in current experimental steam vehicles. In the flash-steam generator, however, the idea of the mono-tube steam generator is taken one step further.
The crucial difference between these two types of steam generator is that, as previously explained, the mono-tube generator raises steam within a coiled tube which contains water of increasing temperature in the first section, saturated steam in the next section and superheated steam in the final section. Steam is admitted to the engine cylinder by means of a valve. In the flash steam generator, however, the coiled tube contains water only. The coil is heated in a similar way to that in the mono-tube generator, the difference being that the water is pressurized to a level above its saturation temperature and is injected into the engine cylinder as water.
cont:
